 Post subject: PCB for a WD800 needed
PostPosted: May 29th, 2010, 4:03
i get i IDNF problem and i assume that there is a PCB problem.
the model number is : WD800JB-00CRA1
thank you
 Post subject: Re: PCB for a WD800 needed
PostPosted: May 30th, 2010, 20:08
hi,
please let me know the model of your drive. or you can contact me by email/MSN directly. thanks.
data recovery service[/b]
PostPosted: May 30th, 2010, 22:14
Pls let me know the PCB number like 2060-******-00* REV * so that we could match what you need. Pls contact my hotmail.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
PostPosted: May 31st, 2010, 3:44
It's not the PCB.
TRANSLATOR
Use the search button above.
PostPosted: May 31st, 2010, 5:15
the number is 2061-001102-300 E.
is the translator problem fixed by changing the pcb (swapping the chip i mean)
or can it be fixed with F/W update?
thank you for your response
PostPosted: May 31st, 2010, 5:30
No.
No. :)
You will need a special equipement SW/HW to regenerate translator.
And the most important thing : you have to know what you are doing.
If your data is important then you have to seek for a pro. It's a strange issue for you, but DR company/man doing this almost everyday.
good luck
PostPosted: December 26th, 2010, 20:43
can you tell more on this "special equipement" ?
ps: got IDNF too
Please (free) help :
http://rzr.online.fr/q/hdd#
how to unlock/format ST3120026A in max security ?
"ALPINE - 1_Disk M.14 01-16-03 11:51"
PostPosted: December 26th, 2010, 22:12
ps: got IDNF too
ATOLA Insight / PC3K / SD tools .... etc
What's your HDD model ?
 Post subject: WD400BB-00CCB0 : translator issue
PostPosted: December 27th, 2010, 5:11
WD400BB-00CCB0
seems to be a translator issue too
see the logs about it :
http://rzr.online.fr/q/ata
PostPosted: December 27th, 2010, 8:45
PM sent.
PostPosted: December 27th, 2010, 21:33
many thx ...
I wish i could do this from linux , but I managed to boot a livecd of windows and reset the translator now i'm dumping a broken partition w/ ext3 fs
while i am here do you know if this device has issues w/ SMART capabilities I cant manage to set it back ...
cron
