 Post subject: Hot swap on Hitachi laptop drive
PostPosted: July 18th, 2010, 8:00
Hi all,
Just a quick question: is it possible to do a hot swap on Hitachi laptop drive?
It is: HTS541080G9SA00.
I got two identical drives, one of them (that needs recovery) doesn't go ready, second one (a donor) is working perfectly fine.
Thanks.
 Post subject: Re: Hot swap on Hitachi laptop drive
PostPosted: July 18th, 2010, 8:38
no you can't.
PostPosted: July 19th, 2010, 8:06
Spaz is right, there are too many adaptives that will not be compatible after the process. Also, even if was successful, there is too many data-dependent adaptives such as defect tables and zone tables etc.
not reaching DRDY is not a lot of info to work with, try explaining problem in more detail, maybe someone here can help, but I suspect that professional diagnosis may be needed.
PostPosted: July 20th, 2010, 2:51
No two drives are identical these days I am afraid.
A hot swap will not be enough to get access to the failed drive.
PostPosted: July 20th, 2010, 15:37
There is a way to do hotswap, but you should have a lot of knowledge including how to deal with unique adaptives, not all the same-model drives is good for this, and you need to have special equipment to work with this drive.
If you have and know all, than yes, you can do hotswap. :)
But if you have missing something, you should seek for professional help.
Janos
Users browsing this forum: No registered users and 271 guests
