 Post subject: Terminal log error
PostPosted: August 12th, 2010, 16:18
Hi to all! :mrgreen:
HD082GJ
ENG>SRV>
SvoTbl Loaded
CL DB06 CM DB4F SL ECBC SM ECCB
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
*** Break at 0x006B [from Trap]
006B: 003E
DBG>DBG> SPW 1.5G LinkOk!
FlashCheckSum Ok!
00017FFF 0000 E94E5V: 04940
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0004
DAC: 7086
SK C: 000195B3
ENG>SRV>
SvoTbl Loaded
CL DB06 CM DB1D SL ECBC SM ECAA
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
006B: 003E
Нет ничего невозможного
 Post subject: Re: Terminal log error
PostPosted: August 12th, 2010, 16:49
Sure PCB is original?
PostPosted: August 13th, 2010, 10:53
Yes original!
PostPosted: August 13th, 2010, 11:08
Can you get SA access? Did you try to access SA after hotswap also?
PostPosted: August 13th, 2010, 14:35
Thanks reply! :mrgreen:
I'm looking for a hdd to try the hot swap :wink:
PostPosted: August 20th, 2010, 14:05
Solved!! :mrgreen:
Users browsing this forum: No registered users and 206 guests
cron
