First of all thanks for all your replies and fast response.
Alexii wrote:
When u say the drive vibrates, do u meen u can feel the platters inside the drive spin? The beeping u had before reversing the power and blowing PCB sounds like seized platters. Oh , and a small square chip is probably voice coil controler, not a diode.
I'm not sure if they actually spin, but it seems more like they try to spin. Could that be a seized motor? Oh and actually its not a square shape, its a rectangular shape. Here are some pictures.
I have with a high resolution scan (1200 dpi) and Photoshop tried to make the writing on that chip readable. It says: QE R729
Thanks in advance
Edit: I had bought the donor drive on the assumption that I could exchange platters based on this tutorial (which uses a drive that is similar to mine), which I have to admit uses a very unprofessional and unsafe method, but uses one that is accessible to me.
http://www.drivelabs.com/hard-drive-rec ... 30608a.htm
