 Post subject: Seagate 80GB S.15 PCB needed!
PostPosted: August 31st, 2010, 16:52
Hi All,
I am looking for a PCB to match the following HDD:
Seagate Barracuda 7200.7 80 GB
Model: ST380011A
P/N: 9w2003-032
Configuration: DZT-04
FW: 3.16
Date Code: 04023
Site Code: AMK
The Terminal output: Appine-1 Disk S.15 01-16-03 11:51
I tried three PCBs, all with terminal info: Application code incompatible with serial flash code.
Any info and ideas will be welcome.
 Post subject: Re: Seagate 80GB S.15 PCB needed!
PostPosted: September 16th, 2010, 13:26
You can change the firmware to make it compatible with your pcb .
PostPosted: September 16th, 2010, 14:33
If you upload a detailed photo, someone will identify the serial flash chip for you, assuming it is external to the MCU.
PostPosted: September 26th, 2010, 6:47
This pcb has an external ROM , but if u have the tools it is possible to use M14 or M21 pcb on this drive .
