 Post subject: How can I partition my hard drive? Help!!!
PostPosted: September 16th, 2010, 22:50
Hay, guys, first time to ask question here, I just want to connect the information you all provide about the operation of hard drive partition. My hard disk is filled with data, files and some other "rubbish", hah, the running speed of my computer is slower and slower. I have no idea about this, my friend told me I can partition my hard drive, but how, he said he do not know as well. So, help me, guys, I know you are all kindhearted. :D
 Post subject: Re: How can I partition my hard drive? Help!!!
PostPosted: September 17th, 2010, 0:33
If your hard drive is full with data, partitioning will do nothing to seed up you computer. Now is time for new external hard disk and then you can move all your "rubbish" data on external. After moving data you will make a lot of space on your internal hard disk, second is defragmentation, and then your computer will wotk little bit faster but you will see difference in speed.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: September 17th, 2010, 17:54
There are many reasons why a machine may perform slowly.
If you're running Windows, check the number and type of tasks that are running in the background. You can use Task Manager for this. If you're running Windows XP, you can use MSCONFIG to disable some of the unnecessary programs that automatically load on start-up.
To test your hard drive, you can use HD Tune's read/write benchmarks:
http://www.hdtune.com/
http://www.hdtune.com/testresults.html
To optimise your hard drive, after backing up your data, you can use Disk Management to repartition it with separate OS and data partitions.
PostPosted: September 19th, 2010, 1:49
Yeah, thanks for your advise, I will buy a external hard drive. :D
PostPosted: September 19th, 2010, 1:51
I know the disk management can finish the work, but I also heard of that the disk management can not work well, it is true?
PostPosted: September 19th, 2010, 21:16
I haven't heard anything like that. However, I know that Win XP cannot create FAT32 partitions that are larger than 32GB, although it can work with them. Win XP also doesn't understand the newer GUID partition structure, nor does it optimally align the partitions on Advanced Format 4KB-sectored drives.
PostPosted: September 19th, 2010, 23:52
Yes it is possible now with Windows Vista and 7. In Disk Management you can resize partitions but in your case is one hard disk and windows is unable to change system partition.
PostPosted: September 27th, 2010, 21:36
Ptaak:
http://www.hdtune.com/results/Seagate_ST3120813AS.gif
That is what it should look like, more or less. If you see severe drops off the curve, falling from time to time, to 5 or 10 Mb / sec, and the locations are the same on each run of the test, then the drive itself is failing and needs to be replaced. A fair number of drives are like that, they slow down before they start developing large numbers of bad sectors.
As for partitioning and drive cloning before partitioning, I will say "Hiren" but I cannot say more than that.
http://www.youtube.com/user/TerraformingMaster
Users browsing this forum: Majestic-12 [Bot] and 99 guests
