 Post subject: [WANTED] WD PCB 2060-701590-000 Rev A
PostPosted: June 28th, 2010, 15:21
Hi guys,
I found this place in my desperate quest for the PCB for a WD1600AAJS-22L7A0 on which the number is 2060-701590-000 Rev A.
If anyone could help me out that would be great!
-Bryan
 Post subject: Re: [WANTED] WD PCB 2060-701590-000 Rev A
PostPosted: June 28th, 2010, 18:14
hi,
i have it in stock. and for this type of PCB need transfer original FW PCB into good PCB that just simple swap PCB won't help at all. i can help you transfer FW. please contact me by email or MSN if need help. thanks.
data recovery service[/b]
PostPosted: June 29th, 2010, 10:27
We have this working PCB in stock. Pls contact my hotmail.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
PostPosted: November 24th, 2010, 22:06
Hi Bryan,
I need to source the same PCB (WD 2060-701590-000 Rev A) to replace a burnt out one for a client's external hard drive.
Did you manage to get one?
If so where from and how much?
Did you simply replace the original PCB or did you also have to swap IC's?
Many thanks
Chris Appleby
PostPosted: November 24th, 2010, 22:49
hi,
i have this PCB in stock. does your PCB has ROM(postition U12) or no?
if so just swap original ROM chip from bad PCB to good PCB
if no you had to do firmware transfer. i can help.
PostPosted: November 25th, 2010, 1:36
If you upload a detailed photo, one of us may be able to help you repair your board. Many times the problem is only a shorted diode, in which case it can simply be removed.
