 Post subject: Fujitsu MHW2120BH CA06820-B38800AP
PostPosted: November 26th, 2010, 21:02
Friend's drive MHW2120BH CA06820-B38800AP failed with data not backed up. Is it necessary to get exactly the same PCB model (the few I've found are very expensive), or is it possible that a drive board that, say, begins with CA06820- might work?
Any help is appreciated.
Steve
 Post subject: Re: Fujitsu MHW2120BH CA06820-B38800AP
PostPosted: December 5th, 2010, 3:11
If the controller board is bad, you need to get an identical one with the same firmware.
PostPosted: December 5th, 2010, 23:07
What failed. Power supply, heads, internal SA. You do not give us a whole lot to go on. This needs a better diagnostics in order to go on. Tell us more details of what is failing and what the drive is doing.
Iorana Haraharaini
PostPosted: December 6th, 2010, 1:55
if you need fine out the PCB for replace please post the model of your PCB. i can check for you.
data recovery service[/b]
Users browsing this forum: Majestic-12 [Bot] and 18 guests
