Forum rules
 Post subject: I would need pinouts, for a linear 2.5 volt regulator
PostPosted: December 10th, 2010, 13:48
I would need pinouts, for a linear 2.5 volt regulator that is in Seagate ST3750330AS, the regulator has 6-pins and it is located above the SDRAM chip.
There are following numbers and characters on top of the IC
9822
1(or something like that)L02
2.5
 Post subject: Re: I would need pinouts, for a linear 2.5 volt regulator
PostPosted: December 10th, 2010, 17:18
ST1L02PM, Very low quiescent bicmos voltage regulator, Fixed output voltage: 1.8V, 2.5V, 3.3V:
http://www.datasheetarchive.com/pdf-dat ... 630896.pdf
http://www.st.com/stonline/products/lit ... /11242.pdf
Here is an equivalent part that is sometime used:
LP38691SD-2.5, 2.5V, 500mA LDO CMOS Linear Regulator, National Semiconductor, marking L119B:
http://www.national.com/ds/LP/LP38691.pdf
These URLs should help you identify the components:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
BTW, "9822" appears to be a YWW (Year/Week) date code, ie week 22 of 2008.
Users browsing this forum: No registered users and 28 guests
