 Post subject: WD800BB-00JHC0 INVALID MODEL NUMBER (XYZ)
PostPosted: December 26th, 2010, 15:22
HI
I HAVE WD800BB-00JHC0 .
1- POWER ON CLINKING --- READY STATUS
2- LOAD MANAGMENT CLIKING THEN I GOT INVALID MODEL NUMBER (XYZ).(SEE PICT)
NO MODULES APPEAR TO UPDATE MOD 11.
PLS YOU ADVICE.
REGARDS
 Post subject: Re: WD800BB-00JHC0 INVALID MODEL NUMBER (XYZ)
PostPosted: December 26th, 2010, 20:55
SD has a case study for this problem. Have you tried to find it on their blog site. You can start here on this one.
Iorana Haraharaini
PostPosted: December 26th, 2010, 22:21
One defective head or SA damage.
PostPosted: December 27th, 2010, 1:12
i believe that u will need SD resources for that. modules issue
what is ur hdd SN?
PostPosted: December 27th, 2010, 4:24
what is ur hdd SN?
Hi to all.
I used SD case study for this problem but i got same problem .
PostPosted: December 27th, 2010, 11:49
Try to swap pcb if you have a donor for that one...
I have a similar problem were rom on pcb was corrupted
PostPosted: January 12th, 2011, 4:13
Drive is clicking, so it's 99% certainly heads/preamp.
Incompatible version/ROM corruption can cause the "XYZ" symptoms, but not usually clicking.
