Forum rules
 Post subject: Seagate 7200.12 1TB models
PostPosted: February 16th, 2011, 11:15
Hello
I'm trying to figure out if my drive is a Barracuda 7200.12 or not.
The problem is that seagate lists the model ST31000524AS on its website as the Barracuda 7200.12 1TB drive while I have a ST31000528AS.
Also, does anybody know the differences between these two models?
I think mine (the 528AS) is a PHARAOH drive, but I don't know the codename of the other one.
Best regards
 Post subject: Re: Seagate 7200.12 1TB models
PostPosted: February 16th, 2011, 12:55
Top right corner of the white label should say 7200.11 or 7200.12
ST31000528AS = 7200.12
difference between 7200.11 and 7200.12 is a slightly different architecture.
PostPosted: February 16th, 2011, 17:07
if you just google the model - ST31000528AS - it shows as a 7200.12
You can see the drive on Seagate's site here.
PostPosted: February 16th, 2011, 19:19
The ST31000524AS is a 6Gb/s drive whereas the ST31000528AS is 3GB/s:
http://www.seagate.com/www/en-us/produc ... rd_drives/
Barracuda SATA Product Manual, Rev. A (ST31000524AS):
http://www.seagate.com/staticfiles/supp ... 36864a.pdf
Barracuda 7200.12 Serial ATA Product Manual, Rev. C (ST31000528AS):
http://www.seagate.com/staticfiles/supp ... 29369c.pdf
PostPosted: February 16th, 2011, 19:26
Thanks a lot fzabkar
PostPosted: February 21st, 2011, 15:44
lol this marketing about the new sata is amazing :lol:
PostPosted: May 16th, 2012, 10:26
Can I use a ST31000524AS and a ST31000528AS in a raid configuration?
PostPosted: December 13th, 2012, 14:27
These two drives can be used together in a raid configuration at 3Gbs/sec. One of my four ST31000528AS's failed in a raid 1+0 configuration and was replaced by Seagate under warranty with a ST31000524AS which worked fine after swapping them out. All four drives are 1TB and connected to 3Gbs/sec ports on the mobo.
