 Post subject: Looking for Hitachi Laptop PCB - Model:HTS541060G9SA00
PostPosted: March 10th, 2011, 5:08
I send my HD to a data recovery after sudden power off. It was not able to be identified by windows on external enclosure, & the clicking sound will be heared for 10 seconds everytime i try to connect it.
The company's evaluation report mentioned that it's a PCB failure, & they requested 500 Singapore $, which i found too much :roll:
There is nothing crucial in this HD, just some family pictures i forgot to backup previously..... so i decided to dot it my self & try to replace the PCB.
PCB required:
Hitachi Travelstar
Model: HTS541060G9SA00 - SATA
Boarad Label first two lines: 0A26800
DA1189A
Thanks In Advance
 Post subject: Re: Looking for Hitachi Laptop PCB - Model:HTS541060G9SA00
PostPosted: March 10th, 2011, 8:18
I'm not a DR guy, but if the drive spins up, then it doesn't sound like a PCB problem to me.
If you wish to replace the PCB, then you will need to transfer the 8-pin NVRAM chip, or its contents, from patient to donor. I can't see their markings, but U3 and U6 are the most likely suspects. Can you identify the part markings?
BTW, there appear to be 3 fuses on the PCB -- F1 (2A), F2, and F3.
PostPosted: March 12th, 2011, 1:02
hi,
have it in stock. please feel free to contact me by email or skype. thanks.
data recovery service[/b]
PostPosted: March 12th, 2011, 7:52
thanks fzabkar for you prompt response.
I'm not an expert, but as per my basic knowledge that HD will not spin or click if its PCB issue.
U3: 25FV055T
5HN4K
U6:RL66
W684
5T
I hope this is the info you are looking for.
PostPosted: March 13th, 2011, 3:22
My understanding is that U6 is the NVRAM that needs to be transferred to your donor. Your supplier should be able to confirm this.
BR93L66RF-WE2, Rohm, Microwire BUS Serial EEPROM, 256×16bits, marking RL66, SOP8:
http://www.rohm.com/products/databook/g ... 76-w-e.pdf
http://www.rohm.com/products/databook/e ... r93l-e.pdf
U3 is a serial flash memory.
LE25FV055T, 512Kbit, 64Kx8, Sanyo, Serial flash memory, 8-pin:
http://www.semiconductor-sanyo.jp/ds_j/NA0447.pdf
PostPosted: March 13th, 2011, 22:01
fzabkar, thanks buddy...
I really appreciate your response & help.
So hypothetically if the PCB is the problem, changing U6 will be the only thing i need to do before swapping, right ?
another question, is it enough to found a matching board (first two lines) , or i need to find a board also has the same model number, hd size, P/n , MLC numbers ??
PostPosted: March 14th, 2011, 19:30
I'm not in the data recovery profession, so I can't offer accurate PCB matching advice. However, I would match as much as possible and then transfer U6. Your PCB supplier should be able to confirm whether a particular board is compatible.
PostPosted: March 15th, 2011, 1:58
Thanks a lot buddy.
PostPosted: March 16th, 2011, 1:23
hi,
my PCB model 0A26800 DA1189C
main chip: 0A26228
