 Post subject: Hitachi HDS725050KLA360
PostPosted: April 25th, 2011, 16:03
I need to flash my SATA HDS725050KLA360 with new firmware. Does anyone know of a utility I can use for this (Linux / Windows is fine)
Thnx!
 Post subject: Re: Hitachi HDS725050KLA360
PostPosted: April 25th, 2011, 16:32
Why do you need to update the firmware?
PostPosted: April 25th, 2011, 18:53
You may be able to use the --fwdownload option in hdparm.
For example, the author of this tech note has successfully upgraded the firmware on Seagate ES.2 drives using Dell MA0D firmware:
https://ata.wiki.kernel.org/index.php/Talk:Known_issues
However, see his warning:
http://sourceforge.net/mailarchive/foru ... ls-support
That said, if Hitachi has made an update available, then the updater should have been packaged with it.
PostPosted: April 25th, 2011, 19:29
We dont even know why the person wants to update the firmware. Sometimes its wise to sit back and wait.
PostPosted: May 3rd, 2011, 12:51
I need to flash it so I can use it on a storevault NAS unit. Without flashing the firmware it's not recognized.
PostPosted: May 3rd, 2011, 17:57
That's odd. And another HD is recognized by the NAS?
Maybe you need to update the FW of the NAS and not of the HD.
ACELab partner
PostPosted: May 4th, 2011, 13:01
No. The NAS forces you to use their own drives (same exact model) and they charge $800 for 500GB. If I can gte a tool to flash the hitachi then I can avoid this. The NAS of end of life so I really need to hitachi flashing tool to get this done
PostPosted: May 18th, 2011, 11:06
I can see you guys are as helpful as ever. :)
PostPosted: May 18th, 2011, 11:27
No such thing, this is not how hard drives work
Users browsing this forum: Google [Bot] and 137 guests
