 Post subject: Adata 16G
PostPosted: May 2nd, 2011, 12:57
Hi I have problem with my USB Flash.
I am try format flash on NTFS file system, but now it's flash ... (gone?)
dmesg:
USBMSC Identifier (non-unique): c5735e2078c498 0x125f 0xc72a 0x100
com_seagate_IOPowSec00 overriding init
com_seagate_IOPowSec00: No ValidUSBVendor found
com_seagate_IOPowSec00: GetVendorAndModelIDInfo failed
Couldn't alloc class "com_seagate_FDEBootStrap"
System Profiller:
A-DATA USB Flash Drive:
Capacity: 16,17 GB (16 173 236 224 bytes)
Removable Media: Yes
Detachable Drive: Yes
BSD Name: disk2
Product ID: 0xc72a
Vendor ID: 0x125f (A-DATA Technology Co., Ltd.)
Version: 1.00
Serial Number: c5735e2078c**8
Speed: Up to 480 Mb/sec
Manufacturer: A-DATA
Location ID: 0x26200000
Current Available (mA): 500
Current Required (mA): 98
Partition Map Type: Unknown
S.M.A.R.T. status: Not Supported
Any Help?
( dd if=/dev/zero of=/dev/sdb1 bs=512 count=1 not working)
Thank You!
 Post subject: Re: Adata 16G
PostPosted: May 2nd, 2011, 19:19
I don't see any relevant error messages in your posting, nor any history etc. so please give the readers here a possibility to help you, by supplying more information. Here are some examples of information which would be helpful (but I don't guarantee that this is a complete list - more questions are possible):
- What is your objective? (Data recovery? I don't *think* so... Or just to be able to use this USB drive when formatted to NTFS?)
- What OS are you currently using - Linux? BSD? Something else?
- Do you have access to a machine running Windows? (There are some helpful utilities which only run on Windows.)
- Do you know that this USB drive was fully working before you tried to format it as NTFS? If so, then *how* do you know e.g. what testing did you do?
- How long have you been using that USB drive before now?
- What filesystem format was being used before you tried to format it as NTFS? (FAT32? ext3? Something else?)
- What made you decide to try formatting this drive - did you see any errors *before* you tried to format the drive as NTFS?
- Do you have the host messages showing the eror messages which were logged when you *first* tried to format the drive as NTFS and saw a problem?
- You mentioned that you tried to run "dd if=/dev/zero of=/dev/sdb1 bs=512 count=1". What exact error message was logged in the host messages when you did that?
FYI, it is *possible* that the reason for this behaviour, is that the USB drive is not really the 16GB capacity which is claimed. Do you have proof that the drive really has 16GB of Flash? (For example - have you successfully copied 16GB of data to it (using any filesystem type) and then read/verified that 16GB of data was successfully stored on the drive? Or used some other testing method?)
PostPosted: May 10th, 2011, 12:00
If you have tried to format then data is not important, and cost for high capacity flash is not so high.
If in doubt, replace it. :)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 16 guests
