Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 500GB (ST9500325AS) 5400rpm PCB Problem
PostPosted: April 7th, 2011, 7:18
i am also sure there is some problem with the track 1 mm track is shot
PostPosted: April 7th, 2011, 7:20
i can see a golden point near the shot diode on my green PCB
PostPosted: April 7th, 2011, 7:27
how can i get current the flowing through the shot track ?
PostPosted: April 7th, 2011, 7:47
i can clearly see some part of pcb track enamel stickng to the leg of blown diode
and it has damaged the track
PostPosted: May 11th, 2011, 6:02
i am not able to find same PN but able to find same Model number what to do?
PostPosted: May 11th, 2011, 7:35
Are you looking for someone to buy a replacement PCB from?
Data Recovery Cape Town
PostPosted: May 11th, 2011, 8:16
yes if possible
PostPosted: May 11th, 2011, 8:18
Check PM.
PostPosted: July 16th, 2011, 13:32
problem solved got replacemnet PCB and changed Bios everything is fine.
8$ PCB
PostPosted: January 25th, 2012, 7:12
8$ PCB
Dear Momentuz,
Can You tell me where You bought de replacement PCB for 8$ ?
Thanks <> Tuin
Users browsing this forum: Google [Bot] and 118 guests
