 Post subject: Fujitsu ROM or PCB required
PostPosted: May 14th, 2011, 12:20
Hi Guys,
Looking for ROM for MHT2040AT xx5C-0022 (xx=don't care)
Or a drive/PCB with this version I can buy/beg/borrow? :-)
Cheers!
 Post subject: Re: Fujitsu ROM or PCB required
PostPosted: May 14th, 2011, 19:04
Fujitsu MHT code should be xYYx - 0022. x don't care, Y needed. If you give me that code, I can send you the ROM.
PostPosted: May 16th, 2011, 4:03
Thanks for the reply.
I've always match xxYY-0022 before and it's been OK, maybe I've been lucky! :-)
My full FW version is 0B5C-0022
Cheers!!
PostPosted: May 16th, 2011, 5:03
Here it is. xxYY - YYYY works up to MHS, but not so sure... MHT is xYYx -YYYY.
Rgds,
ROM.zip [75.17 KiB]
Downloaded 403 times
PostPosted: May 16th, 2011, 6:20
Thanks!
Strange thing is that it's identical to the one I read off the original dead PCB, which I had assumed was corrupt and was killing every PCB I wrote it too.
Further investigation revealed that it was ATA0 on the UDMA I was using, it was corrupting data when writing the ROM, tried again using ATA1 and it worked fine.
Data recovering now!
Many thanks, I owe you one!!
Users browsing this forum: No registered users and 76 guests
