 Post subject: WD6400AAKS-22A782 pcb needed
PostPosted: May 17th, 2011, 12:28
Hello. I need a replacement part for my WD6400AAKS-22A782. I can provide more info about the HDD if needed.
The hdd powers up for 10-15 sec after it dies. I think that the PCB it's malfunction, and planing to do a hot swap using Data Compass. Any thoughts about it?
I want to thank you in advance for your help.
 Post subject: Re: WD6400AAKS-22A782 pcb needed
PostPosted: May 17th, 2011, 12:41
Probably not
This doesn't make sense
I suggest sending to a pro
