Forum rules
 Post subject: 1 HD SSD + 2 in Raid0 or 3 in Raid0 ?
PostPosted: June 28th, 2011, 6:57
Dear Friend
I want to upgrade my hard disks
then ask you m,, what the best option?
1* - 1 hd SSD for System 2 and 3 SATA hard drives in Raid 0?
2* - 3 3 SATA hard drives in Raid 0?
2 * - what the best hd SATA3? the links below, to give
see the chart that the seagate is the best model
Seagate ST1500DL003-9VT16L
http://www.harddrivebenchmark.net/high_end_drives.html
http://www.harddrivebenchmark.net/hd...00DL003-9VT16L
He is only 5900 rpm, see
http://seagate.com/ww/v/index.jsp?na...eqPage=Support
but my friend recommended this hd below! it's really lower or better than the hd up?
I need the best seagate Hard Disk
Seagate SATA 1000GB (1TB) 7200 RPM 6Gb / s - ST31000524AS in Raid 0
Almir
 Post subject: Re: 1 HD SSD + 2 in Raid0 or 3 in Raid0 ?
PostPosted: June 28th, 2011, 8:05
Don't know your goal , but Raid0 it is a realy bad idea in any case.
Angel Data Recovery
PostPosted: June 28th, 2011, 8:13
Why ? Raid0 is not the best raid to get best performance ?
what is the best ?
Almir
PostPosted: June 28th, 2011, 8:22
Raid0 has good performance, but has no redundancy. Meaning if a drive fails then your data is lost.
PostPosted: June 28th, 2011, 8:48
Raid0 the best array to lost data fast.
Angel Data Recovery
PostPosted: June 29th, 2011, 4:43
Im know
But im have a automatic backup 3 times a day
what is the best seagate satã 3 to raid 0 ?? ;)
PostPosted: June 29th, 2011, 8:38
@almirf:
This is not a benchmark forum, so I think you are asking the wrong audience. My only comment is that I would never use "green" drives from any manufacturer (e.g. 5900rpm or similar), if I wanted the absolute best performance.
Users browsing this forum: Google [Bot] and 88 guests
