 Post subject: Catastrophic failure in win 2000 after use Mhdd.
PostPosted: November 7th, 2005, 3:30
hi,
i'll try use mhdd on my pc , start UserPort, next start mhdd ( 4.4, 4.6 ) but in all version get little blue screen with message: Catastrophic failure .....
in pure DOS get message:
An unhandled exception occured at: 0x00037936
EINOUTERROR: access denied
0x 00037936
0x 0031C0D4
:cry:
 Post subject:
PostPosted: November 7th, 2005, 9:32
hi,
log from pci scan
HDAT2 v4.01.11 PM (c) 2005 CBL
CPU/RAM/BUS detect...
ţ CPU vendor    : Intel [GenuineIntel]
ţ CPU name      : Pentium III/Xeon Cascades/Celeron (Coppermine)
ţ CPUID standard: F/M/S/ID = 6:0/8:0/1/0 [00000681h], max. levels = 3
ţ RAM : 254.94 MB
ţ BUS : PCI
BIOS detect...
ţ BIOS: Award Software Inc.
   Version : Award Modular BIOS v6.00PG
   Name    : Award Software Inc. - 04/23/90
   Date    : 09/25/01
   Revision: 0
   Model   : FCh
   SubModel: 01h
   Features: [ 74h 00h 00h 00h 00h ]
   Extended BIOS Segment:9FC0h
ţ APM detected: ver. 1.2
ţ PnP BIOS detected: ver. 1.0
   CS Entry : F000:BD38h
ţ BIOS32 detected: rev. 0
ţ PCI BIOS detected: ver. 02.10
   Configuration Space Access Mechanism 1 supported
   Special Cycle Generation Mechanism 1 supported
   Number of PCI bus = 2
CMOS check...
CMOS size = 128 bytes
CMOS battery power      = 80h -> O.K.
POST diagnostics status = 00h -> O.K.
Shutdown/Reset status   = 00h
   -> Power-on or Soft reset
ROM scan...
1. ROM address C000:0000h, Size = 40 KB
PCI header:
  Vendor ID       : 8086h   -> Intel Corporation
  Device ID       : 7121h
  Class Code      : 00h/00h/03h   -> Unknown/Undefined
Detect floppy drives...
CMOS detected 1 Floppy Drive(s).
First  Floppy Drive: 3« 1.44 MB
Second Floppy Drive: none
BIOS detected 1 Floppy Drive(s).
[0/0 0000h/0000h/00h] 3« 1.44 MB
Checked 1 Floppy Drive(s).
Detect on-board ATA/ATAPI devices...
[0/0 01F0h/03F6h/0Eh] disabled or not exist
[0/1 01F0h/03F6h/0Eh] ST310014A
[1/0 0170h/0376h/0Fh] ST340016A
[1/1 0170h/0376h/0Fh] disabled or not exist
[2/0 01E8h/03EEh/00h] disabled or not exist
[2/1 01E8h/03EEh/00h] disabled or not exist
[3/0 0168h/036Eh/00h] disabled or not exist
[3/1 0168h/036Eh/00h] disabled or not exist
PCI scan...
1. BaseClass: Storage, SubClass: IDE
BaseClass = 01h, SubClass = 01h, Programming Interface = 80h
Bus = 0, Device = 31, Function = 1, Header Type = 00h
Host: Vendor ID = 8086h, Device ID = 2411h, Revision = 02h
Vendor Name: Intel Corporation
Address 4 - I/O Port = 0000F000h
Primary   channel: I/O Port 01F0h, IRQ 14 (compatibility mode)
   -> Drive 0/1: Base Clock = 33/66 MHz, Cable = 40/80 conductor
Secondary channel: I/O Port 0170h, IRQ 15 (compatibility mode)
   -> Drive 0/1: Base Clock = 33/33 MHz, Cable = 40/40 conductor
Bus Master: supported and enabled
Bus Master Control Register: F000h
Built-In Self Test: NO
PCI devices...
Found already detected devices
Detect Ext.INT13h devices...
BIOS 80h: ATA -> already detected
BIOS 81h: ATA -> already detected
Detect OS...
Detected OS DOS, version 6.22 Microsoft
DOS is in HMA
Memory management: DPMI (CWSDPMI or a Windows DOS box)
 Post subject:
PostPosted: November 7th, 2005, 13:02
Catastrophic failure window should give you some explanation (message)...
 Post subject:
PostPosted: November 7th, 2005, 16:24
hi,
win 2000 SP3
message: Can't create log file, after reset all file ( like in Q2 from FAQ) mhdd make log catalogue and wait for port ATA.
address port is 3, after this message Can't access PCI registry ( maybe Windows is running ).
- next message is like "An unhandled exception occured at: 0x00037936 "
 Post subject:
PostPosted: November 8th, 2005, 10:30
MHDD can not work under Windows...
 Post subject:
PostPosted: November 8th, 2005, 13:28
hi,
'll try use mhdd on my pc , start UserPort, next start mhdd...
- but victoria, and HDAt2 working good.
:cry:
 Post subject:
PostPosted: November 8th, 2005, 14:55
It is not a big deal to disable scanning of the PCI bus (or make a command line switch to allow to do that), this will prevent MHDD from crashing on some PCs... But what is the point to run any of such software under Win? :-)
 Post subject:
PostPosted: November 8th, 2005, 15:50
hi,
- i use pure XP, I'll don't like DOS.
- if use DOS, I must make one more partition.
THX for info.
 Post subject:
PostPosted: November 8th, 2005, 16:13
You do not have to make any partition, just download a boot floppy image, or, if you do not have a floppy drive, then download a bootable iso to burn on a CD...
 Post subject:
PostPosted: November 9th, 2005, 6:27
hi,
thx, boot floppy image is working.
:lol:
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 516 guests
