 Post subject: Need NEWB help with WD15EARS-OOMVWBO
PostPosted: July 8th, 2011, 13:05
Hi there....I'm very new to the forum and to this whole concept of recovering data. I have a problem and was wondering if anyone could help me with it.
I fried my PCB by plugging in my laptop power cable and not realizing it until I smelled the burning. I can clearly see that one of the chips is burnt. I found a PCB with the exact same specs, by ordering a new drive. The drive has the exact same specs and the number on the drive (2060-771698-002 RevA) is an exact match. I tried to do a switch, and the adapter is recognized (its a USB external adapter) but the drive is not recognized.
I realize there may be something that I have to do with the BIOS, but I don't know what to do at all. Does anyone have any suggestions on this? I really would like my data back, but spending a couple grand to recover it is way outside the budget.
Thanks!
Enor.
 Post subject: Re: Need NEWB help with WD15EARS-OOMVWBO
PostPosted: July 8th, 2011, 13:22
Straight PCB swap will not work.
Search this forum for "TVS" and you will probably find your answer to the "burnt chip" :P
PostPosted: July 8th, 2011, 13:41
Thank you, but I did a search for that term and it didn't let me. Any other suggestions to add to the search? Thank you!
PostPosted: July 8th, 2011, 13:49
How about DIODE as a keyword and/or MULTIMETER
PostPosted: July 8th, 2011, 14:09
Thank you so much. Is there any way that you can show me on this picture where the TVS Diode is? I thought that it was a burnt chip, but it doesn't look as obvious as I though it did the first time I looked at it. I definitely smell burning and the drive doesn't power up, so it does sound like it could be that.
http://www.flickr.com/photos/hdd-donor/ ... hotostream
I'll try to upload my own picture later, when I have access to a digital camera.
Thanks again for the help! I feel like things are looking up. :-)
PostPosted: July 8th, 2011, 19:36
Hey there, I've uploaded a couple pics of the PCB board if anyone has a chance to take a look and see if they see anything obvious. I'm just not seeing anything obvious like I thought I did at first.
http://imageshack.us/photo/my-images/96/img3359jh.jpg/
http://imageshack.us/photo/my-images/600/img3360y.jpg/
It seems like the burning smell is concentrated more around the area with the 4110 on it. After it heats up a bit it starts.
Thanks again for all the help!
Enor.
PostPosted: July 8th, 2011, 20:20
D3 and the other one next to it on the right hand side. Yes a picture of your board is required for us to see what burned and go from there.
PostPosted: July 8th, 2011, 20:47
So if I (somehow) remove both D3 and the one (I'm assuming you mean it's the one in the corner that looks very similar) then I should be able to run it, at least long enough to get the data off of it? Or am I misunderstanding?
What is the best way to remove them?
Thanks!
PostPosted: July 8th, 2011, 21:42
Check them with a multimeter if not sure how use google how to check diode. You need soldering iron to remove them.
PostPosted: July 8th, 2011, 21:50
If they are bad, I should just remove them? Should I then solder the spot then?
PostPosted: July 9th, 2011, 7:40
If bad just remove
PostPosted: July 13th, 2011, 9:45
Use flush cutters to snip the pins of the bad diode. I haven't tried fingernail clippers, but they might just work, too.
BTW, a 19V laptop adapter usually takes out D4, not D3.
Measure the resistances of zero-ohm resistors R64 and R67 on the 200 ohms range of your multimeter. They should both be close to 0.
Users browsing this forum: No registered users and 101 guests
