 Post subject: ST3160811AS deat after self test HLP PLZ!
PostPosted: August 5th, 2011, 9:47
Hi all, i have one never used Seagate Baracuda 7200.9 160Gb ST3160811AS FW: 3.AAE
This drive is not detected by BIOS, i'm run self test thrue terminal adptar and now drive communicate in terminal only on level F>. Is any idea how to repair this device? Thanx in advance.
Best regards.
 Post subject: Re: ST3160811AS deat after self test HLP PLZ!
PostPosted: August 5th, 2011, 13:23
You have screwed the fw most probably. It is possible but it is an annoying procedure, requires a good copy of entire fw and an HW tool . Otherwise you need to know how fw works and write your own tools.
PostPosted: August 5th, 2011, 23:29
Thanx, can im find somewhere on the net FW for this drive and manual for repair it?
PostPosted: August 6th, 2011, 1:29
Fw most probably yes, what you can't find is the tool - that is HARDWARE, and not like an adapter - and the rest. Or you have to work out your own tool and sw. Quite useless for a cheap drive that has a 15-25$ aftermarket value. Try asking the nearest pro that has the necessary tools to do it , it should be a few $ job.
PostPosted: August 9th, 2011, 6:33
so, i can't repair it using terminal adapter or any other way by my self?
PostPosted: August 9th, 2011, 6:51
By terminal NO.
By other means, yes, assuming someone will explain you how. Note : I don't have all this time and this is not the place.
Users browsing this forum: Bing [Bot] and 199 guests
