 Post subject: Seagate loader req'd
PostPosted: August 10th, 2011, 10:52
Hi guys,
Got an ST9100823A here that just stays BSY
Anyone have a loader I can try please?
ST9100823A (Apple)
FW:3.06
Cheers!!
Sean
 Post subject: Re: Seagate loader req'd
PostPosted: August 10th, 2011, 15:16
this is Momentus (MERCURY) hdd 5400.2 CORRECT?
i got
ST9100828A 3.ALC
ST9100824AS 7.24
do u have the SD tools as well?
PostPosted: August 12th, 2011, 9:03
Thanks but they are not even close :-(
I do have SD tool, yes. But gathering dust!!
I have several UDMA which I use 24/7 :-)
PostPosted: August 15th, 2011, 4:28
You must run a big operation, Sean, if you have several PC3Ks :D
Data Recovery Cape Town
PostPosted: August 15th, 2011, 8:28
Not necessary that big Nick!!
Just like to be able to work on several jobs at once. Keeps the throughput up and clients happy!! :-)
PostPosted: August 17th, 2011, 11:08
Sean,
I have:
ST9100823A - 3.00
ST9100823A - 3.01
ST9100824A - 3.04
PostPosted: August 17th, 2011, 15:26
Thanks guys, but still having no joy.
Tried a couple of loaders people have kindly sent me but it hangs after loading app data and still stays BSY
Strangely no messages in terminal at all after "buzz"... Just sits there spinning.
PostPosted: August 18th, 2011, 5:29
I had a few 7200.7 jobs that gave nothing after "Buzz", stayed BSY and I could not reach T> or F> after CTRL+Z.
turned out was heads after all.
I know are the disks are completely different, but symptoms are so similar I thought was worth mentioning.
