Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: September 16th, 2011, 12:09
Yep, I know what your saying though.
Not much to derive from some simple text on a computer monitor.
Well as long as he pays my boss, so I get my commission, then I have no worries. if not, my Sup can take up legalities with the customer. :wink:
But thanks anyways. I appreciate all of your hard work and time. :D
PostPosted: September 17th, 2011, 9:13
dick wrote:
shredderofdabc, Well done for dumping the file! Password= dope :lol:
This password is incorrect.
I explained to my customer that he may not be able to get the data from his drive recovered, and he said that would be fine, but not proffered.
He said it's his Laptop and did not steal this system. and he doesn't seem the type to me anyhow, he's in the Marine Corp.
So it's either this, or if anyone knows a way to just wipe the drive all together without saving the data, for a fresh start, I'm open to all suggestions.
PostPosted: September 17th, 2011, 11:57
There are different ways of entering the password but you have never said which input method you are using. It is worth reading through the thread again or even searching through this and other threads on the same subject and you will see what i mean.
PostPosted: September 17th, 2011, 13:04
@shredderofdabc:
With respect, I believe that statement to be false. IMHO the password given to you by dick is correct - but as I pointed out previously, the customer will likely only be able to use it, when entered in the same way as he set it originally. How can he not know how he set the password (and not recognise that password!), if it's his laptop and he set the password?
PostPosted: September 17th, 2011, 21:05
Well I tried entering it in hdat2, and mhdd 4.6, and they pop up with either Fail (mhdd) or action cancelled in hdat2.
I wanted to try zu.exe, but the current system I'm working on does not have an Intel chipset on the Main Board.
The customer claims he has no idea how it happened, he said he turned on his Lenevo, it stalled on booting, so he restarted and it was locked up on him.
Either way though, I don't like the situation he's put me in, I have worked for days on his drive, and I think the whole situtation stinks to high heaven. I think I should inform the customer it's not possible, not to mention the simple fact that a drive like this is probably around 40$ to buy brand new and our services are based off of hourly repair and cost and any items being replaced, and I can definitly tell you he's spent more than the cost of a new drive with us and then some.
So I'm gonna call it a dead drive and tell the customer it's a bricked up and see if he'll just purchase one of hours as a replacement.
But thanks guys I really appreciate your help again. You guys are awesome I couldn't have asked for better help on a post. Thanks.
PostPosted: September 18th, 2011, 5:42
h2oinsyde worked for me as the master password to unlock a ATA WD16000 on an emachine. Along with the use of MHDD.exe Thanks for the help
PostPosted: September 18th, 2011, 12:57
Correct - because neither of those was likely the method which was used to lock the drive.
And so he's claiming that his laptop somehow managed to set a short English word as a hard disk password, as part of a malfunction?! This seems unbelievable, IMHO, given the specific ATA commands which are needed in ordeer to set a drive password.
My opinion (and, of course, that's all it is) remains that, on balance of probabilities, the customer is not the laptop owner (or at the very least, he is not telling the truth about what happened, and is not doing all he could to convince us that he is the owner, thereby leaving the appearance that he isn't).
PostPosted: November 1st, 2011, 15:17
Hi everyone,
could someone plz find the password for my wd1600BEVS?
attached the 22.bin
THX
PostPosted: November 2nd, 2011, 6:17
Look at line 150 and forth.
PostPosted: November 2nd, 2011, 18:05
line 150 to???
PostPosted: November 2nd, 2011, 18:32
Line 130
PostPosted: November 3rd, 2011, 5:52
Line 130
:roll: Sure?
PostPosted: November 3rd, 2011, 11:25
northwind wrote:
Line 130
:roll: Sure?
FRANKLy, yes.
northwind wrote:
Line 130
:roll: Sure?
FRANKLy, yes.
lol
PostPosted: November 6th, 2011, 16:04
to unlock the MHDD as I do?
I fail
PostPosted: November 6th, 2011, 16:18
civicstyle wrote:
I fail
How did you set the password originally?
PostPosted: November 24th, 2011, 10:18
scusate volevo postare qui....
mi aiutate wd 1600bevt
noin riesco con password qiesto è il mio 22.bin.
sto impazzendo ho provatoi anche con victoria 4.2 ma "get drive error"
mi aiutate vi prego
22.bin.docx [88.73 KiB]
Downloaded 1451 times
PostPosted: November 24th, 2011, 10:38
[img]
[/img]
questo scusate per prima che non si vedeva....
grazie grzie
PostPosted: November 24th, 2011, 12:18
ho provato la user wdcwdcwdcwdcwdcwdcw niente da fare
mi aiutate comunque leggendo i post precedenti , vorrei trovare la password e non mi interessano i dati che sono caricati
la passw è stata impostata forse da mio nipote ad un EEpc 1001 PX ASUS
PostPosted: November 24th, 2011, 19:58
nessuna risposta.......
non mi volete aiutare????????'
Users browsing this forum: No registered users and 82 guests
