 Post subject: SAMSUNG HS12RJF
PostPosted: October 6th, 2011, 10:25
I'm hoping that the combined expertise on this forum may be able to assist me.
I have a Samsung Model: HS12RJF - F/W: 3AL103c4 - PCB#: BF41-00255a that is in need of data recovery.
This is the first Samsung MicroSATA drive that I am working with. when power is initiated to the device nothing sees it (DDI, PC3000, BIOS, etc..), in fact the drive does not spin up at all.
While I'm searching for a compatible PCB to swap with, are there any other "issues" that I should be aware of with this drive? Will a PCB swap ruin the SA area of the drive?
Any and all advice would be greatly appreciated.
Thank you.
 Post subject: Re: SAMSUNG HS12RJF
PostPosted: October 6th, 2011, 10:29
If you own PC3000, you must know how to adapt new PCB in order to avoid any possible damage. :)
www.datarecoveryne.com
PostPosted: October 9th, 2011, 18:25
If you read some of the manuals of those tools, you'll get there.
PostPosted: October 13th, 2011, 4:56
If you upload a detailed photo, maybe someone could help you narrow down the problem.
PostPosted: March 9th, 2012, 9:56
Did you ever figure this issue out? I'm having the same problem with the same drive, I posted it here http://www.deepspar.com/forum/showthrea ... ng+hs12rjf as well
Users browsing this forum: Google [Bot] and 314 guests
