 Post subject: Fried WD5000AAVS- 00ZTB0
PostPosted: October 30th, 2011, 23:31
I have a Western Digital drive with the following specs:
WD5000AAVS- 00ZTB0
DCM: HANCHT2MBB
with PCB bar code: 2061-701444-J00 AB
The logic board is clearly fried, as in I saw smoke and the board is now black around a couple of chips.
I'm computer savvy and would like to recover the data myself. I thought a pcb swap would do but I heard that I have to match the model (WD5000AAVS- 00ZTB0) and the 5th and 6th digits of the DCM (HANCHT2MBB) for it to work. Others said, it'll never work because of adaptive data on the drive. I don't know who to believe.
I also found it impossible thus far to find someone who has exactly this drive so I can even try it out.
What are my options? Would a PC3000 help? If so, how much is it? Can I buy another board with the same pcb number and reprogram it?
Any help would be appreciated.
 Post subject: Re: Fried WD5000AAVS- 00ZTB0
PostPosted: October 31st, 2011, 2:50
Hi, no need to match the DCM code for Pcb swap.
Just match a Pcb with 701444, and move over the adaptives.
If your Pcb have the ROM in a chip at U12 then it's that to move, if it does'nt you need to seek out a pro.
Regards/ Bosse
http://www.rescue-it.se
PostPosted: October 31st, 2011, 3:51
Bosse is correct, DCM is not the criteria for PCB exchange.
You WILL need to get the "adaptive" ROM info transferred, either by chip transfer or by programming a new one with PC3000 or similar tool. (forget about buying pc3000 unless you have $10,000 spare to throw at this drive!)
PostPosted: October 31st, 2011, 17:17
Salvation Data's HD Doctor for WD is a far cheaper tool for a one-off job. It should cost you less than US$600, and afterwards you should be able to resell it for $300.
I'm not a data recovery professional, but here are two articles that appear to illustrate the required procedure.
Case Study on WD ROYL Drive Using WD Utility (regenerating ROM data)
http://www.salvationdata.com/blog/data- ... y-tools02/
Fix Identification Problem caused by Corruption of ATA Overlay module or ROM content (ROYL):
http://www.salvationdata.com/blog/fix-i ... m-content/
BTW, which chips were damaged?
Users browsing this forum: No registered users and 88 guests
