 Post subject: Terminal output after head change
PostPosted: November 14th, 2011, 6:58
Hi all,
I have changed heads on Seagate ST3750640AS (using the great tool manufactured by HDD Surgery) and now the terminal output is this:
AT Er 00 Nwt Er 43 RdWr 0011d.06.0014
ATA St d0 Er 00 Op 24 e, 575457cb,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.7f7 0000 005f 0000 0001
DiskAccess ReadSector EC=16 at 00011d.06.0014
CE Log ErrCode=43 LBA=2f19ef Type=5 Add To Pending 2f19ef
$$$SFI
AMR
(S)SATA Reset
AT Er 00 Nwt Er 47 RdWr 0011d.06.0015
ATA St d0 Er 00 Op 24 e, 575456ca,0001 0001 0000
Niwot: 97f29ff7 b6 97f29ff7.3.64d 0000 005f 0000 0001
DiskAccess ReadSector EC=16 at 00011d.06.0015
CE Log ErrCode=47 LBA=2f19f0 Type=5 Add To Pending 2f19f0
$$$SFI
AMR
(S)SATA Reset
AT Er 00 Nwt Er 47 RdWr 0011d.06.0016
ATA St d0 Er 00 Op 24 e, 575457c8,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.64b 0000 005f 0000 0001
DiskAccess ReadSector EC=16 at 00011d.06.0016
CE Log ErrCode=47 LBA=2f19f1 Type=5 Add To Pending 2f19f1
$$(S)SATA Reset
SFI
AMR
AT Er 00 Nwt Er 43 RdWr 0011d.06.0017
ATA St d0 Er 00 Op 24 e, 575456c7,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.6f2 0000 005f 0000 0001
Cloning is going on but only partially. (Most of the sectors are red or yellow.)
Any hints, please?
 Post subject: Re: Terminal output after head change
PostPosted: November 14th, 2011, 9:53
$$$SFI
AMR
(S)SATA Reset
That's a NightHawk isn't it. Looks to me like the pending bug. Drive comes ready and IDs right, but you can't really access anything?
Check the ACE forum, there's a step-by-step solution.
Data Recovery Cape Town
PostPosted: November 14th, 2011, 10:49
It looks like the pending bug, indeed.
PostPosted: November 14th, 2011, 19:38
barak wrote:
CE Log ErrCode=43
pending bug can be fixed.
