Post new topic Reply to topic  [ 295 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 15  Next
 Post subject: Re: WD10TMVV
PostPosted: November 2nd, 2011, 4:18
boris888 wrote:
Have the same problem with my HDD, but the model is WD10TMVW, need to get my data.
I hear that it spinned OK, I suppose that the problem with controller. The instruction posted above dosnt have the same pins to connect to SATA.
You need to show us the other side of the PCB.
That said, many people at WD's forums are reporting physical connection problems with the micro-USB connector. It could be as simple as that.
PostPosted: November 2nd, 2011, 4:35
pcimage wrote:
recently I've had a few cases of drives from WD Essential cases that refuse access via the USB and had to be converted to SATA. Not had one like that from WD Passport thankfully, as we'd have encryption to deal with.
Which Essential drives are you referring to?
According to WD's documentation, both My Book Essential and Passport drives have encryption. However, you can order models where encryption has been disabled.
http://www.wdc.com/en/products/products.aspx?id=240
http://www.wdc.com/en/products/products.aspx?id=440
Moreover, the Essential drives that I have encountered (via the forums) are 3.5" models with a separate USB-SATA bridge board.
PostPosted: November 2nd, 2011, 9:00
Thank you for your reply!
I have WD wdbgys0010bbk-u0 model.
When I get it, i turned off any encryption (get experience from) ande deleted WD software from the drive. There was 1 partition, simple ntfs.
Do you mean WD disk controller is making on-line encryption?
Regards,
Boris Glebov
PostPosted: November 2nd, 2011, 9:08
All Smartware WD comes with on the fly ENCRYPTION
PostPosted: November 2nd, 2011, 9:36
That is first side of my the contoller
Einstein.
If I bought another the same drive and change the controllers, can I det my data?
What's the encription method do they use? And why?
Regards,
Boris Glebov
PostPosted: November 2nd, 2011, 10:35
Если диск был куплен в России от белого поставщика (официально) , там не должно быть шифрования .
Правительство запрещает .
If drive was bought in russia , official one, there is shouldn't be any encryptions.
Goverment forbids that
Angel Data Recovery
PostPosted: November 2nd, 2011, 10:38
Dr Kiev , trying to reach u =) check PM =)
PostPosted: November 2nd, 2011, 11:07
Dr Kiev.
I know it, it's activities and right job of our FSB (former KGB - FAPSI) structure. The prohibition is for foreign encryption methods. But there are no any declaration or notification from WD for the methods. And you know the difference: "should be in our country" and reality
Regard,
Glebov Boris
PostPosted: November 2nd, 2011, 11:26
WD Support:
Нюанс накопителей для российского рынка в том, что для сертификации устройств, поддерживающих шифрование, нужно выполнить одно из двух условий: обеспечить неустойчивость шифрования для его легкого взлома правоохранительными органами в случае чего, либо просто передать ключи от стойкого алгоритма в ФСБ. Зачастую в консьюмерских устройствах в итоге эта функция просто отключается - уж больно дорого сертифицировать оказывается. В enterprise все еще хуже: серверные диски с аппаратным шифрованием на борту, насколько я знаю, в РФ вообще не поставляются именно по этой причине
Angel Data Recovery
PostPosted: November 2nd, 2011, 11:50
I've just tried to connect with another simple USB cable, but the same situation.
Any advice?
Regard,
Glebov Boris
PostPosted: November 2nd, 2011, 16:02
Here are the SATA Tx/Rx connection points:
http://www.users.on.net/~fzabkar/HDD/WD ... _Tx_Rx.jpg
You need to remove capacitors C90-93.
I don't know which pair is Tx or Rx, but the 4 signals will probably be in the same order as a SATA data connector:
http://pinouts.ru/HD/serialATA_pinout.shtml
PostPosted: November 3rd, 2011, 0:27
fzabkar
Great Thanks fzabkar, but without your help I cannot understand where is TX/RX contact points exactly. And why I need to remove the capacitors?
Regard,
Glebov Boris
PostPosted: November 3rd, 2011, 3:39
You need to remove the capacitors in order to disconnect the symwave SW6316 bridge IC.
The Tx/Rx signals are the 4 plated through-holes inside the squares.
I suspect that they are arranged either as ...
Transmit+, Transmit-, Receive-, Receive+
... or ...
Receive+, Receive-, Transmit-, Transmit+
MCU                capacitors            symwave bridge
Transmit+    ----x-----||-----------
Transmit-    ----x-----||-----------
Receive-     -----x----||-----------
Receive+     -----x----||-----------
Make your SATA connections at the points marked "x".
PostPosted: November 29th, 2011, 9:56
in my case it was only a cold solder joint at the USB connector
I was able to backup all data bending the cable at the connector a bit
I will now remove the controller and resolder USB connector
maybe that will help others....
PostPosted: November 29th, 2011, 17:03
Many, great thanks for fzabkar!
And Russian specialsts, who helped me
All data recovered.
PostPosted: December 1st, 2011, 2:53
Can anyone confirm that both U12 and U14 need to be swapped when the PCB has failed?
PostPosted: December 1st, 2011, 13:55
For the benefit of other readers, the question from sknopp above was just answered on the new thread created here:
pcb-replacement-for-wd10tmvv-t21303.html
PostPosted: December 1st, 2011, 14:00
Technically all I said is that U12 needs to be moved
I think it would be more beneficial to read some other threads
PostPosted: December 1st, 2011, 15:18
Understood drc :) I was just trying to avoid people replying to sknopp here, without them knowing about your reply in the thread that I linked (started by the same poster), and therefore hopefully avoiding duplicated effort etc.
PostPosted: December 1st, 2011, 16:37
Apologies for the confusion. I posted on this thread and then thought that it might get overlooked given the length of time it has been around and the number of responses it had already received. Will be more patient next time.
Users browsing this forum: No registered users and 70 guests
