 Post subject: WD caviar Eagle not dislapyng Serial & Capacity
PostPosted: December 3rd, 2011, 12:29
Got this Caviar WD2000BB-00GUA0 with dead pcb.
I Replace his PCB but not the rom, donor has same family.
But i got:
Model: WDC WD2000
Serial (empty)
Firmware ok, displayed
Capacity: MB()
so i went into Hotswap with translator, but can't read any sectors neither.
With the pcb of the donor i am only able to read all modules, and they are fine.. :shock:
SA structure test.zip [3.13 KiB]
Downloaded 282 times
 Post subject: Re: WD caviar Eagle not dislapyng Serial & Capacity
PostPosted: December 3rd, 2011, 12:57
With Donor PCB:
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 83970
Head Count.............................. : 5
SPT..................................... : 900
RAM:
Zone allocation table................... : Ok
ROM version............................. : 08.E4.
SA FW version........................... : 21.8WJ
Link table version...................... : 02.GA.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : From map
Heads number............................ : 6
The number of heads in use.............. : 5
Disabled heads.......................... : Yes
Head map................................ : 0,1,3,4,5
Service area:
Modules table loading................... : Ok (Copy 0)
Configuration loading................... : Ok
Master Password......................... : "WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD"
User Password........................... : has not been set
Translation overlay checking............ : Ok
PostPosted: December 5th, 2011, 5:36
found out that head map of donor is different than patient.
patient 0.1.2.3.4
donor 0.2.3.4.5
No way to get data by hotswap! :roll:
PostPosted: December 9th, 2011, 13:27
patient 0.1.2.3.4
donor 0.2.3.4.5
hey positivebit
can you send me another private message with an email to contact you??
I cannot reply to private messages yet, I am blindato being a new user, it seems
Users browsing this forum: Google [Bot] and 48 guests
