 Post subject: ST31000528AS No access to terminal
PostPosted: January 7th, 2012, 15:38
Hi everybody
I have seagate ST31000528AS 7200.12 with a bad SMART (no access to DATA). I want to clear the SMART but I don't why I have no access to terminal. I tries to access to terminal with another HDD, I succeded (It means that my terminal card is working)
Acelab told me that I need to short circuit this drive, but first I first I should identify the pins (which I don't know)
here are the picture of the PCB (front and back)
http://imageshack.us/photo/my-images/268/dscf4939z.jpg/
http://imageshack.us/photo/my-images/252/dscf4944.jpg/
 Post subject: Re: ST31000528AS No access to terminal
PostPosted: January 8th, 2012, 22:37
Hint: check the commonality of all PCB cases and their shortning points presented by Ace in their Seagate F3 manual/document.
PostPosted: January 10th, 2012, 7:10
Check page 16 of UDMA F3 manual
PostPosted: January 10th, 2012, 8:14
I have some examples for various drives:
http://www.users.on.net/~fzabkar/HDD/RW_TestPoints/
The read test points can be identified by a single resistor (eg 100 ohm) connected across the differential pair at the MCU end.
The write test points are either not externally terminated, or they may have a 50 ohm resistor between each member of the differential pair and ground.
PostPosted: January 13th, 2012, 11:10
Hi, first I would like to thank you: fzabkar, freakzy and labtech for the replay.
I think I found it
http://imageshack.us/photo/my-images/26 ... oints.jpg/
When short circuiting the points, the hdd recalibrated thats all, nothing happened, still have no access to the terminal (unselected)
Anyone had the same case :?:
