 Post subject: Western Digitial - WD1600 wanted
PostPosted: January 11th, 2012, 18:06
Hi, does anyone have one of these? Burnt out PCB here
Western Digital Caviar WD1600
Model: WD1600JD-00HBB0
DATE: 17 Jul 2004
DCM: HSBACTJAA
Revision #: 2060-001267-001 Rev A
 Post subject: Re: Western Digitial - WD1600 wanted
PostPosted: January 12th, 2012, 0:04
I have a WD1600AABS in hand. Let me know if it meets your needs. Thanks
PostPosted: January 12th, 2012, 11:52
Unfortunately, this PCB is not compatible.
www.datarecoveryne.com
PostPosted: January 12th, 2012, 17:05
DATE: 17 Jul 2004
DCM: HSBACTJAA
Almost certainly will have this PCB but you WILL need to transfer the ROM chip. Or we can do it for a small fee. PM or email if interested.
PostPosted: January 27th, 2012, 19:54
Hi
I have the same disk - WD Caviar WD1600JB and the pcb on mine burned out too..I watched it happen...!
Up until the the drive was working fine, I removed the pcb and can see the damaged chip, top right most chip on the pcb..which I am assuming is not the ROM chip referred to above..I assume that refers to the biggest square chip in the centre of the board?
So my point is, please, pcimage.co.uk, what would be the cost of returning the drive complete with damaged pcb for reference and matching, and having it returned to me with the replacement pcb installed including ROM transferral?
If you would prefer, please send an IM. As this is somewhat of an odd request, I have posted it here rather than via your web page.
Thanks for reading!
PostPosted: January 27th, 2012, 19:57
Actually I just saw your online quote request, I have submitted there too. Thanks
