 Post subject: Require some advice on seagate 7200.11
PostPosted: January 12th, 2012, 12:16
Hi All,
I have a seagate barracuda 7200.11 issue. The drive doesn't spin and hasn't been dropped. Opened in a clean chamber and the spindle moves freely. Platters seem undamaged, no remenants on the air filters through microscope and the heads are on the platter due to no parking ramp.
I suspect PCB damage, probably more to the fact the drive is completely dead. I've checked TVS diodes and they produce fine results. No visible damage, even through microscope, so is it a possibility that the motor controller has died?
Drive specific information is stored in the ROM, but the firmware is still on the platters i believe, when attempting to hook it up to HD Doctor, not working due to not spinning, mind i'm checking once more tomorrow.
Now the interesting bit. I was looking through some spares we have, and i've found a PCB with same matching codes but on a bigger model.
I have ST3750630AS | PCB code is: UJAJ-6 100466824 | PCB Sticker is: 100468979
Donor ST31000340AS | PCB Code is: UJAJ-6 100466824 | PCB Sticker is: 100468979
If i attempt to do a ROM transfer would that work even though the Donor board is specific to a larger model? If it is possible is the ROM chip no.1 or no.2?
http://imageshack.us/photo/my-images/62/photo22xn.jpg/
All the drive specifics from the donor are different, and i mean all (FW/Date Code/Manufactoring location/model etc). Thats why i'm unsure, i read contradicatory things online that say it doesn't matter about that as long as you have a PCB match by sticker code, but of course i would like confirmation.
Appreciate the feedback,
Kind Regards
Chris
 Post subject: Re: Require some advice on seagate 7200.11
PostPosted: January 12th, 2012, 16:40
Assuming the PCB is the problem, then yes you can swap the ROM chip and it will work on this board.
Pretty sure from memory (not at office right now) that chip 2 is the ROM, but please provide the numbers on both of the chips so I can verify that.
Good luck!
PostPosted: January 12th, 2012, 17:06
I second chip 2
Bosse
http://www.rescue-it.se
PostPosted: January 12th, 2012, 17:17
Chip #1 is not a ROM because it connects to the coil above it. That would make it a MOSFET or PWM controller in a switchmode regulator.
PostPosted: January 12th, 2012, 17:31
I appreciate all the feedback, thank you. I will post the chip values up asap.
Again, thanks.
Chris
PostPosted: January 13th, 2012, 8:14
@PCImage
25x40l001 0805 - ROM Chip (Dead Board)
25P40VP 9806H - ROM Chip (Donor Board)
Cheers
Chris
PostPosted: January 13th, 2012, 16:10
Both devices are serial flash memories, ie "ROMs".
See the M25P40 and W25x40L datasheets:
http://www.users.on.net/~fzabkar/HDD/HD ... Flash.html
PostPosted: January 14th, 2012, 9:06
Thanks for all the input, it works fine.
Cheers
Chris
Users browsing this forum: Google [Bot] and 179 guests
