Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: 7200.12
PostPosted: January 18th, 2012, 6:46
Hi to all! :mrgreen:
Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002B001
Busy...
MODEL: ST3500418AS
FIRMWARE: CC38
Нет ничего невозможного
 Post subject: Re: 7200.12
PostPosted: January 18th, 2012, 7:36
Did you try to .12 Smart bug fix ?
PostPosted: January 18th, 2012, 9:07
to connect the hdd beats ten times on and off ...
Rst 0x10M
Rst 0x10M
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.103 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 860.706 msecs
R/W Status 2 R/W Error 84150180
F3 2>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 00256177, File Error 000000D0
F3 T>/1
F3 1>N1
Failed to load overlay 00000004
LED:000000CC FAddr:0028931
Rst 0x10M
Rst 0x10M
ASCII Diag mode
F3 T>
No HOST FIS-ReadyStatusFlags 2002B001/2
F3 2>/2
F3 2>Z
HighPowerMode
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 860.697 msecs
F3 2>
Rst 0x10M
Rst 0x10M
Rst 0x10M
PostPosted: January 18th, 2012, 9:08
You need short circuit for this
PostPosted: January 18th, 2012, 9:22
CHECK PM
PostPosted: January 18th, 2012, 9:33
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
4292853759 99999999 4288684032 FF E7FFFFFF FE7FFFFF FF FFFFFFFF
4294967295 2113536 0 FF FBFBFFBF FFFEFFFF FF FBFFFFFE
4294966783 4294966784 4227858944 FF FFFFE7FF FFFFFFFF FF FB9EFFFF
4286578687 4286579200 2155872256 FF FFFDFFFF FFFF7FFE FF FFFFFFFF
4294967295 8388608 4293918720 FF FFFFFFFF FFFFFFFF FF FFFFFF7F
4294965231 4294965232 2064 FF FFFDFFFF FFFFFFFF 7F DDFFBFFF
4294967295 2064 0 FF FFFDFDFF DFFFCFFF FF EFFFFFFB
4294967291 4294967292 4261411844 FF FFFFFFFF FFFFFFFF BF FFFFDBFF
4294967295 4 4160747520 FF FFFDFFFF FFEFBFFF FF FFFEFFFF
4294963199 4294963200 4096 FF FFFFFFFD BFFFFFFF 20 00000000
1056768 1060865 4293910528 04 400010 000010 40 00000000 SRV_MEM Type 0 Addr 00000000 Cnt 0001
0 4293910528 2048 00 000010 000000 0 01008000 SEEK RD USR WDG CH 000000.0
0 0 0 00 400010 000004 20 00080004 SEEK RD USR WDG CH 000000.0
35651584 35651584 4259315712 80 8008000 000040 0 00000200
4718592 4264034304 4290248704 00 20000000 001000 10 00002000 SEEK RD USR LBA
16777216 12058624 4278206464 00 000002 8000000 0 08000400 SEEK RD USR PBA B 01000080 L 00044000
2048 4278192128 134215688 08 20080000 020000 0 00000220 CAL
0 4294965248 256 00 004410 4400000 0 00000000 SEEK CMP USR WDG CH 040000.20
147456 147456 4294853632 00 1000000 4840010 0 00080800 SEEK RD USR LBA
0 4294819840 0 00 000000 8200010 20 81010000 SEEK RD USR LBA
0 0 0 00 000000 008000 0 00000300 SEEK RD USR LBA
0 0 4227072 00 000008 000001 0 00040000 SEEK RD USR TRK CHS 000100.0.0000 L 00000000
0 0 67 00 000002 0C2000 40 00800000 SEEK RD USR PBA B 20820400 L 00800000
132 132 532348 10 040804 020000 0 00008000 GET_RVFF
0 4294967164 1048576 00 000000 000802 0 00000800 SEEK RD USR LBA
1409 1409 10952 2F 000000 000000 2 84150180 SPN_UP NORMAL
12383 10974 2 1B 000000 000000 1 00000080 MEM_DBG
12385 2 4 2B 000000 000000 1 00000080 PES
12389 4 1 23 000000 000000 1 00000080 SRV_EC
12390 1 16 04 000000 000000 1 00000080 SRV_MEM Type C Addr 00000000 Cnt 3030
12406 16 0 03 000000 000000 1 00000080 RD_CHNL
12407 1 99999999 30 000000 000000 7F FFFFFFFF SPN_DN NORMAL
ASCII Diag mode
PostPosted: January 18th, 2012, 15:48
Solved!! Sucess!
Thanks all helps!!
PostPosted: February 6th, 2012, 3:47
sempre wrote:
Solved!! Sucess!
Thanks all helps!!
Could you help me! :cool:
i have the same problem,how do you resolve it?
PostPosted: March 9th, 2012, 1:15
sempre pls post how to solve it
PostPosted: May 3rd, 2012, 14:54
I have the same issue as above. Sempre, could you please PM me a solution?
PostPosted: May 15th, 2012, 5:23
Hi Hddguy,
I have the same issue. Could you please tell me how to solve it?
Thank you very much
PostPosted: May 15th, 2012, 5:44
Hi Hddguy,
Thank you very much
PostPosted: May 15th, 2012, 22:40
Good day!!
I have 2pcs 7200.12 with same problem i need the data badly..Pls kindly pm me the procedures.
thank you very much
PostPosted: May 16th, 2012, 3:41
sempre wrote:
Solved!! Sucess!
Thanks all helps!!
Hi Sempre,
Thank you very much
Hi Hddguy,
Thank you very much
PostPosted: May 17th, 2012, 16:15
Hey all.. I've been searching like mad. What is this referring to? We're trying to get some data off a drive with basically the same errors.
Thanks :D
PostPosted: May 26th, 2012, 2:47
sempre, Hi ,
Thank you very much
PostPosted: June 26th, 2012, 7:07
Hello guys,
I have the same problem on :
ST3750528AS
HP34
Could you please give us the way to recover data ... here or in PM ...
Many thanks
Alain
PostPosted: July 2nd, 2012, 7:17
sempre, Hi ,
I have the same issue (st350418as). Could you please tell me how to solve it?
Thank you! :wink:
PostPosted: August 7th, 2012, 17:14
Hi to everyone,
Please help me to revive Hdd ST31000528AS with the same problem!!!!
Thanks in advance :wink:
Users browsing this forum: No registered users and 55 guests
