 Post subject: HDD LLF 4.25 Don't read serial number correctly
PostPosted: January 24th, 2012, 3:41
This is my first time using HDD LLF and I found a little bug (o problem), don't read correctly the serial number on SEAGATE BARRACUDA 7200.11 1,5TB, the other data is ok.
THK you.
Paredux
PD: Excuse my bad English
 Post subject: Re: HDD LLF 4.25 Don't read serial number correctly
PostPosted: January 24th, 2012, 8:01
I don't support the LLF tool, but if you can supply some information, then this may help to understand the situation.
Can you supply a photo of the screen (or screenshot), showing the information which you are talking about?
Why are you trying to LLF the drive - what is the original situation? Perhaps your drive is really not reporting its serial number correctly...
PostPosted: June 5th, 2012, 17:30
I was searching for information on this issue and came across this post. I too con confirm that the serial number does not show correctly in HDD LLF -- it is jumbled.
PostPosted: June 6th, 2012, 4:35
THK you.
Paredux
r u using any sata 2 usb adapters? or directly connected?
