Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WD Elements 2.5" 500 GB can't find data
PostPosted: January 29th, 2012, 8:38
Hi guys,
Just got a similar HDD, but it is My Passport, though it is doing soft ticking noises.
Any insights to this problem?
Does a head problem is common on these drives?
Cheers
PostPosted: January 29th, 2012, 10:15
odedshankar wrote:
Hi guys,
Cheers
A, Ticking sounds related to weak/dead heads
B, not a problem if ur drive never felt OR had some power issues
no DIY consult pro. assistance
PostPosted: January 29th, 2012, 15:14
einstein9 wrote:
odedshankar wrote:
I know that elements are not supposed to be encrypted but
its quite weird that the Initio chip was on the PCB - probably didn't use it though.
Initio makes many USB-SATA bridge ICs. Only some incorporate AES encryption.
For example, an INIC-1607E does, but an INIC-1607P does not.
FYI. most of them are: 1607E
Seagate also uses Initio chips, but none of them are INIC-1607E (AFAIK).
Initio chips are used in a lot of generic products as well.
PostPosted: January 30th, 2012, 3:33
u mean the Buffalo FOR SURE & it is again FOR SURE encrypted my dear
i remember i did post a while ago about this. but not same scenario as WD Smartware
