 Post subject: Western digital hd 1tb caviar green not working
PostPosted: January 30th, 2012, 12:04
hi all i have western digital external hd but i accidentally bumped it into a wall and now its not going to turn it on anymore..the bump was very light,but i think i t was enough for the logic card to not work anymore.i have very,VERY important data on it,so i need it to work as soon as possible.it might also be something inside the engine\roto but i0m not sure...what do you suggest me to do
here's the spec
WSTERN DIGITAL 1 TB SATA MODEL WD10EAVS-00D7B1
WWN:50014EE2ACDB244D
DATE:03 NOV 2008
DCM:HARNNT2MBB
LBA:1953525168
AND HERE A COUPLE OF PHOTOS
 Post subject: Re: Western digital hd 1tb caviar green not working
PostPosted: January 30th, 2012, 15:44
EXTREMELY unlikely for a light knock to cause the PCB to fail!
Much more likely for it to cause internal problems.
Not DIY, seek pro assistance.
PostPosted: January 30th, 2012, 19:39
well yeah that's why i was brought here actually,from a friend from another forum..i live in italy and i was looking for someone who can do some data recovery for logic damaged hd,and they suggested me to contact user "BlackST",but it seems that my account is too.."young" to Pm hi mdirectly,so i hope he reads this sooner or later
PostPosted: January 31st, 2012, 4:12
I say again, this is NOT "logic damaged" as you appear to want it to be :-(
Sorry.
PostPosted: January 31st, 2012, 5:30
which kind of damage is it then...-_-
PostPosted: January 31st, 2012, 5:45
It is very likely you have some serious mechanical failure which can not be resolved logically or electrically and 99% cannot be resolved without professional assistance.
PostPosted: January 31st, 2012, 6:13
PostPosted: January 31st, 2012, 6:14
Hehe hddguy, ditto :)
PostPosted: January 31st, 2012, 12:52
Look at markings on PCB and HDD with X seems like he has had this seen by someone who marked this. Not normal he would do this himself. Seems someone marked it and already tried a controller board. I have seen here from IT shops that when they try and swap out controller board they mark thier HDD with an X so they can tell which one they are working on. IT shops here only try a PCB swap out and mark the client drive and PCB with X so they can put it back together again after they try all the PCB they have in thier shop from other drives. Could be wrong on this one but seems that he has tried a PCB already and did not make it work right with donor PCB.
He should contact BlackST in Italy on this one agree it is internal to the HDD.
Iorana Haraharaini
PostPosted: January 31st, 2012, 14:31
I agree, definitely not a simple cheap fix...internal issues, for sure. BlackST is my Italian recommendation.
Recovery Force Data Recovery
PostPosted: January 31st, 2012, 19:20
well yeah unfortunately i cannot contact him through pm because my account still doesn't let me do that :(
PostPosted: February 3rd, 2012, 7:45
what happen if i buy an identical hd (only difference being last twodigits on the pcb,evertyhing is the same)that i saw on ebay,and replace the "discs" inside the newly bought hd with the the one that doesn0t want to start?since this all pcb thing is complicated because it must be exaclty the same,and since probably is not the pcb itselfr,i wanted to this operation and aks if it works.after all im just replaceing the disks inside the hd,not messing with pcb,bioses etc.i went to a professional company that told me somwething similar,except it will cost 700 euros,wich is WAY beyond my money availability.and i should buy that hd on my own anyway...
PostPosted: February 3rd, 2012, 8:13
Solstar wrote:
what happen if i [...] replace the "discs" inside the newly bought hd with the the one that doesn0t want to start?
The chances of you successfully doing that, considering the knowledge, equipment etc. that are required, is approximately zero - and you will likely cause problems / damage that will prevent even a professional from later recovering your data, even if you then paid the money. :( Please read again the comments from pcimage (and other professionals) above.
PostPosted: February 3rd, 2012, 9:26
Che avrai 2 dischi rotti e perso i dati - e i soldi.
That you'll have 2 broken disks and lost data and money.
PostPosted: February 3rd, 2012, 13:23
No professional DR company will make you buy that HD on your own. They can not do this one becasue one the drive might be compatable with yours and then you have spent money you did not need to spend. Two a professional DR company finds their own donor parts. I would not go to this company if they asked you for a new disk and for you to get it for them.
Also this problem is not a platter swap. You do not need to swap out platters on this one. I have one in here that is doing the same as yours. I think after re-reading your first post the bump into the wall and especialy if it was running has maybe stuck heads to the platters. I can not be sure from what you say on this one but this can happen easily.
Even if you swap out platters you will never get back your data. I see here BlackST has posted answer him and try and make contact. If you want a professional in Italy go to him. If you want back your important data go to him. That is all I can say on this one now.
Iorana Haraharaini
ciao blackst paicere di consocerti...capisco il rischio,ma il tizio intanto mia hdetto che devo trovare io un hd similke,poi lui ci prova e FORSE puo' recuperare i dati..alla modica somma di 700 euro,che mi sembra parecchio esagerato se me lo permetti
PostPosted: February 3rd, 2012, 14:37
Mah... sara' .Buona fortuna!
Who knows?... Good luck!
PostPosted: February 3rd, 2012, 15:43
If it's possible, you have LESS than zero chance of successfully transferring the "disks" from one drive to another and getting it to work. Moreover it would be like fitting wheels to a tomato, completely pointless!!
700 euros is cheap for this kind of job, so if you are not prepared to spend that the either wait until you are or say "ciao" your data.
Sorry to be harsh, but this is the fact of the matter.
PostPosted: February 3rd, 2012, 16:22
Totally agree.
PostPosted: February 3rd, 2012, 19:20
Hi, you're discs is not to be replaced...as you're information is on them.
But you're bump might caused the bearing to sized, and you're platters is need to be moved to a good chassie.
BlackST is you're best choise in Italy, and for I know it might not cost you €700..It migth be cheaper than you think.
You might evalue it.
Bosse
http://www.rescue-it.se
Users browsing this forum: No registered users and 116 guests
