 Post subject: PC hardware recommendations for PC3000 UDMA
PostPosted: February 10th, 2012, 7:48
As your aware I'm getting my PC3000 UDMA & PC3000 Flash SSD shortly & I am wondering what motherboard etc to use.
Currently I have a test / training desktop tower pc that is a socket 775 cpu connection, Dual gig lan, SATA2 ports, RAID 0,1,5,10 & 8Gb of DDR2 ram, PCI & PCIe. Have got an old pent 4D 3.4Ghz dual core cpu but was thinking of upgrading to a 3Ghz quad ive seen on Ebay. Would this be worth it or not?
Or should I build a i7 system?
If its ok then would you setup a raid 5 (12Tb) in it to use for storage or buy a NAS RAID 5 storage box?
 Post subject: Re: PC hardware recommendations for PC3000 UDMA
PostPosted: February 10th, 2012, 8:41
building-powerful-workstation-suggestions-welcome-t20443.html
PostPosted: February 10th, 2012, 9:26
guru wrote:
http://forum.hddguru.com/building-powerful-workstation-suggestions-welcome-t20443.html
Thanks yes I had read that, think I just wanted to confirm what I had was good enough.
Would you recommend a nas box or RAID in a PC?
Loki
PostPosted: February 10th, 2012, 9:49
NAS is better, (RAID1) for ur important files
had 4TB before, added new 12TB recently
mine is I7 Extreme 12mb cache + 4GB mem + Asus MB (2 units)
PostPosted: February 10th, 2012, 10:24
IMO PC3K is not dependent on good/fast hardware at all. You will be limited by the speed of the slow/sick/failing drives you are trying to work with.
PostPosted: February 10th, 2012, 10:33
Now that would be great if my boss would also allow me to play BF3
:lol:
PostPosted: February 10th, 2012, 10:37
:lol:
Now thats just cruel :lol: might even be against your human rights :lol:
PostPosted: February 11th, 2012, 3:44
sorry, but again disagree with u here
my DB is like 40GB more or less, searching in my db before used to take 40-1 1/5min on good P4
now not more than 20sec.
in addition MAC FS or Fat32 in DE now are more amazing.
btw & FYI, i did my homework with my stop watch using both options, faster processor helps alot
PostPosted: February 11th, 2012, 4:38
Does PC3000 support Multi Core / multi - thread?
I would be interested to see what a cheaper i5 3.33ghz will be like compared to your expensive Intel Extreme :idea:
PostPosted: February 11th, 2012, 8:50
Well, i guess i know what u mean PM on the way
PostPosted: February 13th, 2012, 14:48
PC3000UDMA -> bottle neck in transfer rate is in failing drives, system must be online 24h/24h so better to have i3 cpu (65Watts against 130W of i5/i7) a good Power (active) + good UPS
PC3000FLASH -> Bottle neck is in cpu+hard drive subsystem, here i have got i7 + SSD as hard drive in SATA6 mode (white colour from mobo)
In both system of course XP 32bit and a good motherboard ( i use asus with power control energy system with SATA6 + USB3.0 )
at the end you will get super stable system, but don't buy mobo with graphic card integrated.
PostPosted: February 13th, 2012, 16:27
Interesting.
can you explain?
I have been running a udma on such machine with absolutely no problem. I chose integrated vga on mobo because i thought it is less power consuming.
PostPosted: February 13th, 2012, 17:45
System memory is shared with VGA memory, this always bring less stability.True about Vga integrated is less power consuption, but if u buy a basic Nvidia with silent cooler you will have only few watts but more clean system memory.
PostPosted: February 13th, 2012, 17:55
This is interesting to test, if you can, just before asking something to DB to open CTRL+ALT+CANC and see cpu performance ( not the spike) and report?
I think you got better result of P4 becouse you had a better hard drive (40GB of database should run faster on a P4 with a SSD than a i7 with a SATA hard drive)
Rgds.
PostPosted: February 14th, 2012, 6:38
Rgds.
Sorry, but disagree with you here, i made my test/homework and SAW the Diff. here
and maybe you did not pay atten. to DE notes i mentioned, try and see it ur self my dear.
PostPosted: February 14th, 2012, 6:47
@einstein9
i did not write about DE in my last post, but about database speed.
PostPosted: February 16th, 2012, 8:31
Did you mean this??
got 2 for testing here
PostPosted: February 16th, 2012, 13:11
yes i meant that..can u test database performance compared to a motor one hdd..
2 in raid 0 could be amazing :lol:
PostPosted: March 8th, 2012, 19:00
May be overkill but I find my ocz ssd makes a massive speed difference when creating tasks in DE
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
PostPosted: March 9th, 2012, 4:27
I'm changing my UDMA machines, will upgrade from old Athlon to this:
i5@ 3,3
4GB RAM
1x SSD OCZ (as per buster's suggestion) for OS and Program Files
1x2TB WD FAEX (for image files etc)
1GB PCI-e Nvidia
Corsair 550W
ASUS Mobo usb3.0 etc
That would cost me approx. 550 euros.
I'll let you know how it feels when it's set.
Users browsing this forum: No registered users and 14 guests
