 Post subject: Samsung HD252HJ Terminal
PostPosted: February 11th, 2012, 13:56
Can anybody explain pls?
MaxPhyHead = 0002
RPM at Handoff: 0296
@USSHOS - Released on 2008/01/21 08:3
6 by gt.kim
DRAM=16MB SoC=26A3
SHOS-(1AC08c0M.a11)
L=00000000,00000000
<SpinOn_2>KeepSpinOn!
RV Circuit Enabled
Temp : 34 degC
SpinOk
mServoStatus1 00000003
SK C: 89136 H:0
ServoTable Loaded
FdtTable Loaded
| 19 | RLIST | 3 | 0 | 66 | 1340 |
AP:2 C: 2009 H:1UF 6 GrayFailErr
Vel Parking!
PK_3 C: 1643 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 1643 H:1
SK C: 85609 H:0
S_2 000000D9 000000D9 00000000 00000000AP:1 C: 2009 H:1UF 6 GrayFailErr
Vel Parking!
PK_3 C: 1608 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 1608 H:1
SK C: 86460 H:0
S_2 00000063 00000063 00000000 00000000AP:1 C: 2009 H:1UF 6 GrayFailErr
Vel Parking!
PK_3 C:160612 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C:160612 H:1
SK C: 89024 H:0
S_2 000000BA 000000BA 00000000 00000000AP:1 C: 2009 H:1UF 6 GrayFailErr
Vel Parking!
PK_3 C: 1604 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 1604 H:1
SK C: 86151 H:0
Vel Parking!
PK_3 C: 1631 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C: 1631 H:1
SK C: 87747 H:0
S_2 000000C7 000000C7 00000000 00000000AP:1 C: 2010 H:1UF 6 GrayFailErr
Vel Parking!
PK_3 C:158855 H:1
UF 3 1stGrayErr
Vel Parking!
PK_3 C:158855 H:1
SK C: 87920 H:0
CONTINUES...
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Samsung HD252HJ Terminal
PostPosted: February 11th, 2012, 14:24
Bad head/heads
PostPosted: February 11th, 2012, 14:32
thx networks
by the way, i found the drive UNSCREWED of the HEAD base while client gave the hdd. (may be he tried to open the hdd, or opened the hdd) client can't clarify this one. he gave the drive to local tech there before giving me.
Is it possible to know if it was opened in normal environment (Not in Clean Room)?
PS: I don't have Clean Room here, so i m not going to open this to check. I will give idea about pricing to go for outside of Bangladesh to take service in clean room.
__________
THANK YOU
SHAHI
PostPosted: February 11th, 2012, 18:30
I don't know of any method to discover if the drive was "not" opened in a clean room. With the info you have I would assume it has been opened. you should be able to tell based on the top cover screws if that is what you meant by the term "head base" ?
PostPosted: February 12th, 2012, 1:40
Thanks ...
__________
THANK YOU
SHAHI
PostPosted: February 13th, 2012, 3:20
Also most of the times, if a drive has been opened in a non-clean environment, then if you examine the surface with a microscope, you can clearly see particles of dust. Sometimes they're visible with bare eye.
But, that would mean you would have to open the drive to check, which is something you don't want to do, as you said.
PostPosted: February 13th, 2012, 14:10
You are right. I don't want to open physically to check as I don't have the CR here. Just want to advice and help the client for having his data back.
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 66 guests
