 Post subject: WD1600BEVT-11ZCTO modules needed
PostPosted: February 18th, 2012, 10:46
i have a 2,5'' WD1600BEVT which tested with PC3K and saw that 0002 module is not working. i want to repair it. does anyone can attach the rom files for PC3K or can i download it from a link?
thank you
 Post subject: Re: WD1600BEVT-11ZCTO modules needed
PostPosted: February 20th, 2012, 6:03
if i use WD3200BEVT-11ZCT0 modules (which i have) is there any chance of fixing the problem or i will make it worse?
thank you
PostPosted: February 20th, 2012, 6:07
Have you tried to read with error skipping to check where is the bad sector location?
Also, it's bad on 2 copies?
PostPosted: February 20th, 2012, 13:35
802f offset x200
PostPosted: February 20th, 2012, 14:22
yes, on both copies the 0002 module is "broken"!
PostPosted: February 22nd, 2012, 4:22
But there's some readable area on any of them?
PostPosted: February 23rd, 2012, 2:03
I think mulan is saying that a copy of MOD 02 is embedded within MOD 802F at offset 0x200.
FWIW, I notice that MOD 100 has a directory that refers to a third (?) copy of MOD 02. Maybe you could search the tracks for it ...
PostPosted: February 23rd, 2012, 13:04
yes dmarques. is readable but there is a problem with the specific module. i will try what fzabkar mentioned and tell you.
thank you
PostPosted: February 23rd, 2012, 13:18
Can you send me both mods, from copy0 and copy1 to check?
PostPosted: March 13th, 2012, 8:32
i attach and the copy0
SABackup.rar [2.82 MiB]
Downloaded 359 times
PostPosted: March 13th, 2012, 8:42
the log file
wd1600bevt-11ztc0.rar [1.49 KiB]
Downloaded 353 times
PostPosted: May 3rd, 2012, 22:29
athlesi7 wrote:
the log file
HDD Rom is corrupt, you need load another.
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
Users browsing this forum: Majestic-12 [Bot] and 44 guests
