Forum rules
 Post subject: HDD Firmware update
PostPosted: February 29th, 2012, 20:19
How to update HDD firmware chip.which (programmer) adapter can use?
Thank you
 Post subject: Re: HDD Firmware update
PostPosted: March 1st, 2012, 1:53
Hahahaha :lol:
PostPosted: March 1st, 2012, 4:32
If you are asking how to reprogram the serial flash memory chip that you see on most HDD PCBs, then here is one way:
read-write-serial-flash-wdc-logic-boards-t7192.html
Alternatively, there is PonyProg freeware, but you will need to construct a simple interface circuit:
http://www.lancos.com/prog.html
Be aware that the bulk of the drive's firmware is stored in a hidden System Area on the platters:
newbie-info-from-and-for-newbies-about-firmware-etc-t6562.html
PostPosted: May 3rd, 2012, 21:34
Kalimuthu should read carefully, not easy for a beginner who want to update HDD firmware.
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
PostPosted: May 3rd, 2012, 22:17
Thank you
Why do you want to do this firmware update?
PostPosted: May 4th, 2012, 3:01
Here is another way:
http://www.drivestar.biz/adapter-sop8-s ... p-661.html
... plus ...
http://www.ebay.co.uk/itm/24-EEPROM-25- ... 231c06e9ec
... plus something like this, but with 2x4 pins:
http://media5.rsdelivers.cataloguesolut ... 471-01.jpg
PostPosted: May 4th, 2012, 3:22
HDD are not cell phones. If yuo do this you can destroy your drive. Plus why do you want to do this?
Iorana Haraharaini
