 Post subject: Help me, What to watch in HD replace the PCB damaged
PostPosted: March 1st, 2012, 9:28
Help me, What to watch in HD replace the PCB? because my PCB fumes when burning. SATA 3.5 "Seagate Barracuda 7200.7 Model: ST380817AS, S / N = 4MR24YWW, P / N = 9W2932-370, FIRMWARE = 3.42, = 06 027 DATE CODE, SITE CODE = TK
 Post subject: Re: Help me, What to watch in HD replace the PCB damaged
PostPosted: March 1st, 2012, 10:04
Match the pcb number and swap over the rom chip.
PostPosted: March 1st, 2012, 11:50
@northwind; thank you for ur post/ answer,
PostPosted: March 1st, 2012, 11:58
Take a pic of the PCB
PostPosted: March 1st, 2012, 12:00
this is my pcb, 100331799 N7601LLR9, My HD made in Thailand, to replace the pcb pcb proved difficult in finding the same Number, is there an easier way? whether to use a different dps numbers, HD made in china?
Please...
PostPosted: March 1st, 2012, 12:03
Replace the burned diode. Maybe you dont need to replace the entire PCB.
PostPosted: March 1st, 2012, 18:37
:good:
indhay wrote:
to replace the pcb pcb proved difficult in finding the same Number.
Well... it took me 20 seconds..
http://www.ebay.com/itm/Seagate-160GB-S ... 256cac59e0
PostPosted: March 2nd, 2012, 23:15
yaa.. I should replace the diodes are burned, but I did not do it, I am a student. I want to buy a new hard drive, so I could take the PCB on my HD (contains my data), what should be matched (the location of manufacture, firmware, S / N, P / N etc) so that the replacement of PCB work and legible? please help me, thanks all
PostPosted: March 3rd, 2012, 12:26
Helloo...anybody help me?
PostPosted: March 3rd, 2012, 20:33
Match fw # and interface. But diode fix is the cheapest, of course given there is no other damage.
PostPosted: March 4th, 2012, 17:11
indhay wrote:
I should replace the diodes are burned ...
I see only one burnt component, and that's near the +5V pins of the SATA power connector.
I would first check your PSU. Your drive appears to have sustained an overvoltage on the +5V supply.
When you have sorted out your PSU, you can then remove the shorted TVS diode (use flush cutters). If there is no additional damage, then the drive will work without it, but you will no longer have overvoltage protection on the +5V input.
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
PostPosted: March 12th, 2012, 7:53
to labtech and fzabkar
thank you for responding,,, I have a burning diode but change their IC components have been damaged as well. I want to replace the pcb, what should be equated, whether the type, firmware, or other place of manufacture? enlightenment please the master. sorry i come from Indonesia, my conversation is bad. :)
PostPosted: March 12th, 2012, 19:19
I don't know what you mean. Can you point out the damage in your photo?
indhay wrote:
I want to replace the pcb, what should be equated, whether the type, firmware ...
Labtech has told you that you need to match the firmware (3.42).
PostPosted: March 13th, 2012, 3:53
to labtech and fzabkar:
oke thank you all, my problem solved, I have changed it
Users browsing this forum: Rendersmith and 104 guests
