 Post subject: How to deal with this one? Seagate 7200.9
PostPosted: March 5th, 2012, 11:08
Interface task reset
1024k x 16 SDRAM
TLITE - 1_Disk S-6B 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Failed sys sect. write! Nwt Er 33 RdWr 1658d.00.0003
Read Ver Retrys
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 16587.00.0002
Unable To Load Overlay 01|000A
T>
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: How to deal with this one? Seagate 7200.9
PostPosted: March 5th, 2012, 11:32
Update after STUFF RESET
Spin Ready
(P)SATA Reset
Failed sys sect. write! Nwt Er 33 RdWr 16587.00.0003
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 16587.00.0003
T>
PS: THE CONSOLE SHOWS ALWAYS BUSY, NEVER READY
__________
THANK YOU
SHAHI
PostPosted: March 5th, 2012, 12:55
Use a LDR or recover via Terminal in DE...
Assuming you have PC3000?
PostPosted: March 6th, 2012, 2:09
no, i don't have pc3k. sd only
__________
THANK YOU
SHAHI
PostPosted: March 6th, 2012, 3:21
What did you do BEFORE the error ? Hope you have saved the entire SA, but as you are using SD you likely had hard times when working with the disk...
PostPosted: March 6th, 2012, 6:59
This is handled in UDMA, but with SD... good luck...
PostPosted: March 6th, 2012, 7:46
Well, not only by UDMA... :mrgreen:
PostPosted: March 6th, 2012, 8:39
Yes I meant UDMA can handle it. There are other ways too :)
PostPosted: March 6th, 2012, 13:39
The problem was fixed successfully... by using SD...
It's not the tool, it's the know-how... otherwise - no pc3k, or sd or anything else is going to help!
Thanks all...
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot], unknown and 49 guests
