 Post subject: SP2004C - detected as 250GB
PostPosted: March 6th, 2012, 13:35
It's rather peculiar case to me...
MODEL SP2004C. NO SPIN.
Swapped with SAME PCB NO (BF41-xxx), DONOR HDD WAS SP2504C, but same pcb no and revision. It doesn't have any ROM Chip.
Well, now the drive spins but detected as 250GB, as SP2504C (the drive is 200GB and Model: SP2004C)
Load from HDD is fine... Comes to READY.
FW Diagnosis 4 bad modules...
MOVLY001
BOVLY001
BPES2
RCO_LOG
What to do next?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: SP2004C - detected as 250GB
PostPosted: March 6th, 2012, 14:13
shahij wrote:
What to do next?
Learn how Samsung work.
You have the answer if you revise exactly what you have done step by step.
P.S. modules were most probably fine, it's just the way you worked that is not ;)
PostPosted: March 6th, 2012, 17:13
Sounds like the heads map is different, for one.
http://www.datasaversllc.com
PostPosted: March 7th, 2012, 2:43
These drives have ROM in MCU if possible try reading ROM from old pcb or find ROM compatible with your hdd .
PostPosted: March 7th, 2012, 5:53
If you wish to repair your board, and assuming it's feasible, then upload a detailed photo of the component side.
PostPosted: March 7th, 2012, 11:05
This is the image...
The PCB has no visible damage...
Here is the PCB Pic
http://www.donordrives.com/media/catalog/product/cache/1/image/28c43211aab6caf8178d385058449c0e/i/m/img_0073.jpg
__________
THANK YOU
SHAHI
PostPosted: March 9th, 2012, 2:52
Measure the voltages at the two TVS diodes and zero-ohm resistors near the SATA power connector.
If they are OK, then measure the voltages on the pins of the transistor at the top left corner of the MCU.
Measure the voltages on the pins of the transistor between the motor terminals and the motor controller.
Measure the voltages at each of the three (?) coils near the motor controller. Why did you clip this part of the photo, BTW?
