 Post subject: Tools for Toshiba 2.5 sata Hdd
PostPosted: April 17th, 2012, 14:11
Dear friends
I looking for the best tool to work with Toshiba MK
Thanks in advance
Mary
 Post subject: Re: Tools for Toshiba 2.5 sata Hdd
PostPosted: April 17th, 2012, 14:38
If you want the best then buy the UDMA PC3K plan and simple on this one sorry.
Iorana Haraharaini
PostPosted: April 17th, 2012, 16:48
Thank you for you quick answer, but I understand that PC3K don“t support, all the Toshiba models, the model I have is MK1665GSX and is not listed on the supported models list at their web site. Do you know if there any model they have is compatible?
PostPosted: April 17th, 2012, 22:26
Is this your personal drive you want to fix or a drive for a client? If it is your drive then it is a lot cheaper for you to send this to somene who can do it for you. Toshiba drives are not so easy to do DIY on and even if you have a tool to use you still can not do this one without proper know how and experience in this one. Sorry but tools are not your answer on this one.
Iorana Haraharaini
