 Post subject: issues with Seagate 500Gb ST 95000562AS momentus
PostPosted: May 6th, 2012, 3:57
Hi All
got a drive in that is clicking continsually,
replaced ehads and drive came good and showed id straight away, all sounds good
started to image drive and within a couple of minutes it started having reading issues while imaging forward, changed this to reverse and once again drive imaged will for a couple of minutes, then it stoped imaging all together.
restarted drive
it has gone back to clicking 10 times with the following in terminal, after it clicks 10 timss it remains spinning
capacity is identified as 0mb
Rst 0x20M
Elko init complete
Elko Loop Started
Spinup started
FAIL Servo Op=0100 Resp=0007
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF
ResponseFrame 5A60 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 5A60 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 Temp = 30
Initial Spinup complete
SIM: rd FI=00000000
SIM: Check SIM Retry Status.
SIM: FAILED.
SIM: rd FI=00000000
SIM: FAILED. SIM Error FileID 0 Err 1002 ExtErr 38235000
SIM: rd FI=00000195
SIM: FAILED.
(DOS) Table Read FAIL
(DOS) Requesting File Save
any help will be greatly appreciated.
thank you
 Post subject: Re: issues with Seagate 500Gb ST 95000562AS momentus
PostPosted: May 6th, 2012, 4:12
DId the heads "survive" ? (put back on donor / check with microscope)
If not, you have (as most likely happens) media damage, if yes there can be non-supercritical damage BUT / AND the problem is just adaptives AND maybe if the drive was dropped, a bit of "mechanical".
With these heads can you read with no issues or hiccups the SA ?
PostPosted: May 6th, 2012, 19:18
Hi blackst,
Thank you for the answer,
here is the initeresting bit, after writing the post i had restarted the drive again, even though it went on to click for 11 times, this time it came ready and showed full id, i was able to get a full drive backup of resources.
built head map of drive and started imaging by heads, head map is 0 1 2 3, head 1 will not image so i disabled this and built a full image of the other 3 heads,
this morning drive is back to same issue as before, so going to place heads back into donor to see what happens and see if they are still ok.
will post back later on
Users browsing this forum: ccc, MindMergepk and 65 guests
