 Post subject: Need help for hitachi hds721010dle630
PostPosted: May 15th, 2012, 22:54
Pls need help for 1tb hitachi hds721010dle630
1tb
fw:5q0
detected on bios with 0mb and in windows harddisk management its 32mb or 36mb only using harddisk enclosure..
pls help me with this problem ty..
 Post subject: Re: Need help for hitachi hds721010dle630
PostPosted: May 16th, 2012, 1:37
can someone help me pls..
PostPosted: May 16th, 2012, 3:18
See Q2:
http://www.users.on.net/~fzabkar/HDD/HD ... y_FAQ.html
PostPosted: May 16th, 2012, 3:42
@ fzabkrar a very big thanks to you !!
I read also here
lost-partition-hitachi-1gb-hdt721010sla360-t15662.html
lots of back read before i check my topic, your still the one who give the solution..
more power sir
PostPosted: May 16th, 2012, 3:51
is this work also with
seagate 7200.12
jc45 firmware
its was happen when the 2pcs 1tb and the hitachi was use from one pc to another pc for backup disk..
PostPosted: May 16th, 2012, 5:07
It doesn't matter which brand of HDD you have. Gigabyte's BIOS bug buggers them all. :-(
However, note that a drive that reports a capacity of 0 LBAs will probably have an internal fault rather than a HPA. In this case you will see different behaviour in Windows Disk Management.
Users browsing this forum: fouad19764 and 136 guests
