 Post subject: Seagate pcb
PostPosted: June 18th, 2012, 18:19
hello this is my first post in the forum and hopefully learn a lot from you.
I have some old hard drive seagate barracuda 7200.7 specifically one think that this damaged the pcb because it makes a noise something like tik tik as if the disk is trying to start but did not succeed at all, and retry
My question would be possible to repair the pcb or the software update whit RS232 to TTL cable. in order to fix the disk is useless to learn a bit since I have no great idea about seagate ata commands and power them out something useful to this cable to buy to fix my barracuda 7200.11 that was in a state of BSY
Thanks for reed and Forgive the grammar
regards
 Post subject: Re: Seagate pcb
PostPosted: June 18th, 2012, 18:56
the engine noise is not as I thought but that cablezales go from one extreme to another and read the disc
PostPosted: June 19th, 2012, 4:32
probably it's BAD HEAD. no DIY
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: No registered users and 76 guests
