Hello all,
I have a curious disk here. So far:
Full disk image taken of a single HDD, 160GB Seagate 7200.12, just a few hard to read sectors at the end of the disk. File system is partially corrupt, rebuilds with quite a few orphaned files. When opening a file over a certain size (usually somewhere between 128kb and 256kb) the file would be corrupt. I assumed that perhaps the disk had been in a RAID 0 and the customer had not noticed (Dell Desktop), and I noticed that the final sectors on the disk related to a dynamic disk volume (potential for striping).
However, when I examined the the raw data I found an issue I have not seen before. At non-regular intervals throughout the HDD there are 60 sectors of out of place data written to the HDD. This 60 sectors look as if it is pseudo-encrypted or compressed data.
When I am examined the bitmap and the MFT this could be seen clearly. Attached below is an image of part of the MFT where it turns from a normal entry starting FILE0 to the 'corrupt' data.
I've examined the bitmap & mft as a file, assuming the file starts at offset 0 then the following offsets are where the 60 sector corruption starts:
Bitmap: 374, 586, 853, 1163, 1398, 1636, 2395 etc.
MFT: 582 , 843 , 2283 , 2512 , 2701 , 3616 , 4357 etc.
As you can see there is not a regular interval between the start of the 'corrupt' data in each of these files.
Does anyone have any thoughts on this? Unfortunately I was just sent the single HDD, it was removed by the customer's IT support staff member who examined it first. There is of course the opportunity that he ended up writing new data to the drive, but it seems unlikely given how this out of place data is distributed through the HDD.
All the best,
J
