 Post subject: roblems with Seagate Barracuda LP ST32000542AS.
PostPosted: June 24th, 2012, 3:02
I have a problem with a Seagate Barracuda LP ST32000542AS firmware CC94,
I can not get into terminal mode with the command Crt + Z .. I think there is a short to do on the PCB ...
This disc seems to have problems with head ... But I tried to replace them with no positive results .... I think there are problems with firmware.
Can anyone help me?
Thank you and good day to all!
 Post subject: Re: roblems with Seagate Barracuda LP ST32000542AS.
PostPosted: June 24th, 2012, 14:54
Per curiosità come hai cambiato le testine e dove, e da cosa hai dedotto che i problemi erano testine e firmware?
How and where did you change the HSA and how the problem was diagnosed to be heads and/or FW?
PostPosted: June 25th, 2012, 1:16
hello, The hdd was the classic sound of heads clik clik ... substitution is not easy, this disk to 8 heads.
 Post subject: Re: Problems with Seagate Barracuda LP ST32000542AS.
PostPosted: June 25th, 2012, 3:12
Can anyone help me?
PostPosted: June 25th, 2012, 3:34
The question still stands, how did you change the head stack? Do you have prior experience? Equipment? Know-how?
PostPosted: June 25th, 2012, 8:56
Agreed most likely damaged.
lulux69,
To answer your question about the shorting points:
If you look at the pre amp connection points on the PCB you will see a pair of tracks going to the right side of the LSI chip.
Follow the pair of tracks from the preamp connections & you will see 2 test points. You will need to see where they are on the otherside of the PCB.
Remember your accepting all the risks involved when trying DIY.
Loki
PostPosted: June 25th, 2012, 11:54
lulux69,
Loki
Thanks a lot. I try now!
Hello!
PostPosted: September 7th, 2012, 1:42
Hi Guys,
Can you help identify which one in the pic is the eeprom that needs to be transferred to the donor pcb?
Borrowing the pic of lulu69...
PostPosted: September 7th, 2012, 1:45
25XXXXX, maybe? cant's see clearly.
PostPosted: September 7th, 2012, 1:56
the one on the right side has a 40113A number... the one at the bottom as winband 25xxxx
PostPosted: September 7th, 2012, 4:24
Winbond 25x
Data Recovery Cape Town
PostPosted: September 7th, 2012, 5:34
Agreed
It's the (Winbond 25x) 8 legged chip near the bottom right on the photo.
Loki
PostPosted: September 7th, 2012, 12:08
Thanks so much guys....
Another question related to this.
I have an ST32000542AS which was working well, when one day it just suddenly died...no clicking... no spinning..nothing. I ordered a replacement PCB at donordrives.com ( I actually discovered this site through them) and then I replaced the pcb.
After replacing....Voila! it spinned, unfortunately, i then heard a clicking sound for a few seconds at the start up while it was spinning... the difference is that...it will click only on the start up then it will disappear...and the spinning will stop..
The same thing will happen if you power it off and on again...it will spin then click for a few seconds.....
Is this due to the incompatible ROM? or is the head already damaged?
PostPosted: September 7th, 2012, 12:25
Yes, incompatible ROM. Have to resolve PCB issue and then test the heads to find if heads are a problem as well.
PostPosted: September 7th, 2012, 12:28
Did you order PCB with ROM transfer or without?
Edit: I see labtech was first.
PostPosted: September 7th, 2012, 12:39
without sir, i just ordered a donor pcb, I was hoping it would not need a ROM transfer anymore. Besides the site is US based while I am in Asia so it will take weeks or months if I will ship the hard drive back and forth
PostPosted: September 7th, 2012, 13:15
Then you need to transfer Rom aswell
http://www.rescue-it.se
PostPosted: September 9th, 2012, 0:58
Guys....i would like to say thank you all for the great help...you have just saved my ass....i was able to recover the whole 2TB HDD! thank you all!!
PostPosted: September 9th, 2012, 4:27
Nice to hear :)
PostPosted: December 2nd, 2018, 14:53
This is a quite old topic and propably my post is not much helpfull for the user that asked. However there is an interesting video on youtube about how to repair a Seagate Barracuda LP series HDD that is not recognised by BIOS or OS with just a few clicks.
I believe that some less advanced users with same issue that will come to this post, will find this solution usefull. Actually drives like Barracuda ES, Barracuda ES.2 , Barracuda DM001, 7200.12 series and more, with similar symptoms can be repared the same way.
https://www.youtube.com/watch?v=-TO5tfaRszA
Users browsing this forum: Google [Bot] and 199 guests
