 Post subject: Seagate ST3500630AS PCB with chip ST V520AA
PostPosted: July 24th, 2012, 13:09
Hello!
I have a pcb broken (Seagate) with chip st v520AA and also I have an identical pcb but have chip TTB43980.
If I change the chip and eeprom may I run the pcb on that hard drive?
Thank you
 Post subject: Re: Seagate ST3500630AS PCB with chip ST V520AA
PostPosted: July 24th, 2012, 14:18
It doesn't matter that the main chips are different. Just make sure you match the PCB number etched on the other side of the PCB, example: 100530756 REV A
And don't worry about REV A either, REV A works with REV B work with REV C etc.
Swap ROM onto PCB with matching PCB number and, if only PCB was the problem and ROM is not damaged, drive should work.
Data Recovery Cape Town
PostPosted: July 24th, 2012, 15:14
Thank you for your reply.
The hard disk is running well. I had a problem with a track connector. The owner of the hard drive went crazy for a moment. No other explanation. :lol:
Users browsing this forum: ccc and 157 guests
