 Post subject: How can I transfer Firmware from broken HDD to working one?
PostPosted: July 26th, 2012, 22:03
Here's my problem I own a Panasonic DVD Recorder that had a 250GB HDD,
the HDD broke (it's clicking), I bought a replacement HDD of the same make and model
and only made one month difference between them (Dec 2009 instead of Jan 2010) ,
anyway the DVD recorder won't format this new HDD
b.c as I was told by Panasonic the HDD they use has a different Firmware (special firmware just for their dvd recorders)
different from the ordinary the stock model HDD.
Panasonic wants over $100 for the new HDD (the stock model only cost around $40)
anyway is there an easy cheap way to transfer the Firmware
from the Broken HDD to a Working one?, before I pay so much for a new Panasonic spare part HDD?
 Post subject: Re: How can I transfer Firmware from broken HDD to working
PostPosted: July 27th, 2012, 11:09
No there isn't if this is the scenario. And if they use a particular FW there is a reason.
PostPosted: July 27th, 2012, 11:12
It will cost you more to transfer Firmware from broken drive, if its necessary.
Probably have to format new drive to your DVD Recorder specs .
www.datarecoveryne.com
PostPosted: July 27th, 2012, 16:57
Ok thanks
PostPosted: July 27th, 2012, 17:05
Well, I think the hdd inside is NORMAL hdd with ONLY partition issue
the reason am telling you this is I DO HAVE ONE already and saw it
1st. try to use any normal HDD inside and use the screen menu to format it, and IT SHOULD WORK
about your defected hdd, if you needed your DATA, then you will need to seek a pro. to get it for u my friend
good luck
PostPosted: July 27th, 2012, 19:39
That was true with the older models but the newer models (DMR-EH59, DMR-EH69, DMR-EX78, etc)
won't format new HDDs unless they have the special code in their firmware (which only Panasonic sells).
PostPosted: July 28th, 2012, 1:47
...not only Panasonic.
PostPosted: July 28th, 2012, 7:01
Hummm
this is something new really, have to chk :>
thnx both for the info.
PostPosted: July 28th, 2012, 8:39
Also the Newer Models use SATA and not PATA HDDs now.
Users browsing this forum: No registered users and 65 guests
